7 Replies Latest reply on May 25, 2009 12:13 AM by karthik flex
    Scrolling Datagrid?
    karthik flex
      hi guys
      I have one doubt
      When i scroll my datagrid which contains huge data e.g 20 rows
      when i drag down and move up the datas are shuffling means
      the second row data is coming in first row and third row data is coming in second row
      please help
      Karthik.k
        • 1. Re: Scrolling Datagrid?
          _Natasha_ Level 4
          do you use custom itemRenderers?
          • 2. Re: Scrolling Datagrid?
            Gregory Lafrance Level 6
            List based components like DataGrid recycle itemRenderers for improved performance, and you can have scrolling problems. See this link:
            http://devharbor.blogspot.com/2008/09/flex-itemrenderers-and-recycling-issues.html
            If this post answers your question or helps, please mark it as such.
            • 3. Re: Scrolling Datagrid?
              karthik flex Level 1
              hi Natasha
              Yes i am using itemRenderers?
              karthik.k
              • 4. Re: Scrolling Datagrid?
                And using itemRenderers can cause problems with scrolling:
                http://devharbor.blogspot.com/2008/09/flex-itemrenderers-and-recycling-issues.ht ml
                • 5. Re: Scrolling Datagrid?
                  hi
                  i am explaining in detail
                  i have a datagrid and itemrenderer
                  inside that itemrenderer i have data separated with commas
                  it is getting displayed like paragraph
                  but i need to split with comma and display one by one
                  I did the same separated by comma and displayed one below the other
                  it is getting displayed correctly
                  but when i scroll up and down, datas getting shuffled first data in last row when i scroll
                  below is the itemrenderer i am using
                  override public function set data(value:Object):void
                          super.data=value;
                          textData.text=String(data[_
                  listData.dataField]);
                          textData.height=50;
                          textData.width=160
                          arr  = textData.text.split(",");
                           var box:VBox=new VBox();
                          for(var i:int=0;i<arr.length;i++)
                              var text:Text = new Text();
                              text.text = arr[i].toString();
                                 box.addChild(text);
                                  this.addChild(box);
                  i am splitting data, adding to box, it is displaying correctly but when i do scrolling some thing strange occurs like
                  data shuffling what is the problem
                  should i need to do some thing else
                  please help
                  karthik.k
                  • 6. Re: Scrolling Datagrid?
                    _Natasha_ Level 4
                    it seems to be many errors in your code.
                    1. You have added box as a child several times. - It's not good. But it's not the reason of your problem.
                    2. You don't delete existing childs then data changed. Before string
                    you should delete childs from previous call of this function. Something like this.removeAllChildren() or if you know the number of VBox this.removeChildAt(i) or if you save a reference to vbox this.removeChild(box). You don't clean it so you see old data then scrolling.
                    The best variant for you is to save link to your VBox and create it in createChildren method. In set data() function only clean children of this vbox and create new for new data.
                    • 7. Re: Scrolling Datagrid?
                      hi Natasha
                      thank you
                      you saved me i got it
                      Thanks a lot
                      karthik.k
