4 Replies Latest reply on Jul 6, 2009 1:27 PM by AJP256
    Feature request for LiveCycle Designer ES
    SciMax Level 1
      Please consider adding the ability to insert a caption to a radio button group, as well as the ability to insert/or not insert a caption for a checkbox group.  This function is available in Form Guide so I'm hoping it can be done for LD as well.
      Currently if you add a text object (caption) above a group of radio buttons or checkboxes it throws off the tabbing order.  It is also a major design challenge to get the layout to mimic the other objects   AND if you are using a Positioned Content in your Subform this setup cannot be done at all.
      I've attached a sample pdf so you can see the layout I'm describing.
      Thanks for your consideration.
