3 Replies Latest reply on May 21, 2009 2:05 PM by MarcelBoucher
    Invoke long process in flex application
    zubinshi
      There is a long process I created in workbench to save a new member.
      I following a guide here http://livedocs.adobe.com/livecycle/8.2/programLC/programmer/help/wwhelp/wwhimpl/common/ht ml/wwhelp.htm?context=sdkHelp&file=000261.html
      There were no errors showed up by calling the process in flex application, but the process wasn't called(by use recording and play process).
      btw, the process itself works fine if i invoke the process in workbench.  following are my codes:
      public function CreateNewMemberManager(memberId:String, firstName:String, lastName:String, dob:Date)
      addNewMember.channelSet=ChannelSetHelper.getRemoteObjectInstance().channelSet;
      addNewMember.addEventListener(ResultEvent.RESULT, resultHandle);
      this.firstName = firstName;
      this.lastName = lastName;
      this.memberId = memberId;
      this.dob = dob;
      //This method invokes the "add new member" process
      public function executeInvokeProcess():void
      //Create an Object to store the input value for the EncryptDocument process
      var params:Object=new Object();
      params[FIRST_NAME]= firstName;
      params[LAST_NAME]= lastName;
      params[MEMBER_ID]= memberId;
      params[DOB]= dob;
      var token:AsyncToken = addNewMember.invoke_Async(params);
      // This method handles a successful conversion invocation
      private function resultHandle(event:ResultEvent):void{
      Alert.show("Member: "+memberId+" is created!");
      any idea?
