5 Replies Latest reply on May 24, 2009 10:41 AM by Gregg_B
    XMLSocket problem
    Gregg_B
      Hi All,
      I'm trying to use the XMLSocket object to send some simple strings to the Java Server.
      (The java server is just a simple socketServer included in the Flex 3.0 API documentation for XMLSocket)
      Each time I send the string to the server it freezes it.
      For example, I have this in my .as file.
      private function sendToXMLSocket(xmlMsg:String):void
              import flash.net.XMLSocket;
              import flash.net.Socket;
              var sock:XMLSocket = new XMLSocket("localhost", 7778);
              sock.send(xmlMsg);
      I have just a form with one button on it and the above method is executed when I click on that button.
      The xmlMsg string is just this for now: "greggreggreg\n"
      The JavaSimpleServer receives it and I can see it printed to the console but when I click one more time on the button nothing gets accross.
      The messages (and number of messages depends on how many times I click on the button) don't get transmitted unless
      I click on the X to close the window and terminate the program.
      Only then I can see all of the messages on the other side.
      I can't figure what seems to be a problem. I'm thinking that this is happening (maybe) due to the fact that the XMLSocket appends a zero byte at the end of each message sent to the server. Is this a problem?
      By the way, original code for the JavaSimpleServer  was closing an incoming socket connection right after the first message got to it. I removed that line of code (incoming.close()) becasue I'd like to be able to send as many messages as I can. So I need to keep the socket connection open.
      (This all works for me when I send messages from Java client.)
      Can someone help?
      Greg
        • 1. Re: XMLSocket problem
          Gregg_B Level 1
          So I switched from XMLSocket to just plain Socket.
          I have this now:
            var sock:Socket = new Socket();
                      sock.addEventListener(IOErrorEvent.IO_ERROR, onIOError);
                      sock.connect("localhost", 7778);
                      sock.writeUTFBytes(xmlMsg);
                      sock.flush();
          But nothing gets transmitted unless I close the Flex app.
          I don't get this. What seems to be a problem?
          I read an API docs twice and it says that writeUTFBytes (or any other write methods) are just putting stuff in a buffer
          the flush() is the one that signals that the buffer content needs to be sent.
          I'm doing just that and still I get nothing on the other side unless I close the Flex app.
          Any suggestion?
          Greg
          • 2. Re: XMLSocket problem
            _Natasha_ Level 4
            Hi Greg,
            You can write to socket only after Event.CONNECT event dispatched. As I understand for XMLSocket you haven't call connect() method at all.
            See example from docs.
            http://livedocs.adobe.com/flex/3/langref/flash/net/XMLSocket.html#includeExamplesSummary
            • 3. Re: XMLSocket problem
              Gregg_B Level 1
              No Natasha,
              The line:  var sock:XMLSocket = new XMLSocket("localhost", 7778);
              already establishes the connection. Instead of calling the connect() method I just use the constructor of XMLSocket to this job.
              It works and I can send stuff to the server. I can also see it on the server. What causes the problem is the additional
              ZERO Byte attached to the XML string sent. I don't know whose idea was to create such object (the XMLSocket object)
              that gets this additional zero byte at the end. I think is stupid and I'd fired the programmer that design this..........
              I got around the problem using the Socket object instead.
              • 4. Re: XMLSocket problem
                Lopo Nopo
                Hahaha!
                By the way - why do you create a new connection per message every time?
                I'd fire a programmer who does that in a commercial product as well
                • 5. Re: XMLSocket problem
                  Gregg_B Level 1
                  Simply because I can.
                  It doesn't matter at the moment.
                  This suppose to be only a test/sample program for someone smart here to tell me how to married
                  flash client with java server. (how to get the XML string to the other side)
                  I got it to work, however, the problem remains for those trying to do the same.
                  Did you write it?
                  LOL
