2 Replies Latest reply on May 23, 2009 12:33 AM by Mark A. Boyd
    Can you make a 'pie chart' with Lingo ?  or Java
    MAC800 Level 1
      Question pretty much like the subject above says. Just a basic pie chart from two numbers
      Alright, I want a pie chart to give a visual of a percentage.  The percentage would be a value of 1-100 in a field cast member
        • 2. Re: Can you make a 'pie chart' with Lingo ?  or Java
          Mark A. Boyd Level 4
          I do hope you realise that it takes more than two numbers (or one single value from a #field member, as you've supplied) to display anything representing a pie chart. For example what exactly to you want that #field value to represent? Radius? Circumference? Portion of 100%?, etc... And what is this mysterious 2nd number you hint at, but do not define?
          Please understand that while nobody would deny the integrity of any of Valentin's scripts/Xtras, you surely know that it takes much more than two numbers to represent a pie chart - or even a single slice of a given pie chart.
          But, I'll bet that his class can get you there. Just wanting you to think about what you are asking for here.
          BTW, what on earth does Java have to do with your question? Were you thinking about JavaScript when you typed the subject? You are aware that Java <> JavaScript (or even EMCA syntax), right? Were you serious about Java?
          Not a slam, just wanting you to think out loud.
          Mark "Cheers II, SD" Boyd
          Keep-On-Learnin' :-)
          .sigFile addressed at myself, but if the shoe fits...
