3 Replies Latest reply on May 22, 2009 6:03 AM by apmyhr
    Drawing filled polygons
    apmyhr
      I wrote an alrogithm to draw a polygon using an array.  My code looks like this
      var
      points:Array = [{x: -5, y: height}, {x: 0, y: 0}, {x: 5, y: height}];
      this
      this.graphics.beginFill(TimeChartingTool.resourceColors[color]);
      this.graphics.lineStyle(2, 0x000000);
      this.graphics.moveTo(points[0].x, points[0].y);
      for (var i:int = 1; i < points.length; i++){
           this.graphics.lineTo(points[i].x, points[i].y);
           this.graphics.moveTo(points[i].x, points[i].y);
      this.graphics.endFill();
      This draws the outline of the triangle correctly, but it wont fill the shape.  Any suggestions?
      this.graphics.lineTo(points[0].x, points[0].y);
      .graphics.clear();
        • 1. Re: Drawing filled polygons
          apmyhr Level 1
          Sorry for the messed up format of that comment.  It looks like Adobe forum has issues with copying/pasting code to the comment.
          • 2. Re: Drawing filled polygons
            Gregory Lafrance Level 6
            This code may help you. Compare with your code:
            var triangleHeight:uint = 100;
            var triangle:Shape = new Shape();
            // red triangle, starting at point 0, 0
            triangle.graphics.beginFill(0xFF0000);
            triangle.graphics.moveTo(triangleHeight/2, 0);
            triangle.graphics.lineTo(triangleHeight, triangleHeight);
            triangle.graphics.lineTo(0, triangleHeight);
            triangle.graphics.lineTo(triangleHeight/2, 0);
            // green triangle, starting at point 200, 0
            triangle.graphics.beginFill(0x00FF00);
            triangle.graphics.moveTo(200 + triangleHeight/2, 0);
            triangle.graphics.lineTo(200 + triangleHeight, triangleHeight);
            triangle.graphics.lineTo(200, triangleHeight);
            triangle.graphics.lineTo(200 + triangleHeight/2, 0);
            this.addChild(triangle);
            If this post answers your question of helps, please mark it as such.
            • 3. Re: Drawing filled polygons
              apmyhr Level 1
              After reading the API better I realized what I did wrong.  I didn't know that lineTo(x,y) not only draws to x,y but it also sets the current position to x,y.  So all I had to do was remove the moveTo(x,y).
