5 Replies Latest reply on May 22, 2009 8:47 AM by cputnam14
    Combo box set selected text.
    cputnam14 Level 1
      Hey folks,
      I have this wierd thing happening with a combo box. I am using a loop to populate an array. The array is the data provider for a combo box. Everything is working fine exept the first vaule of the array doesn't show up in the combobox as the selected value. I've tried setting the selected index to -1, 0, 1 but it never displays as soon as the page loads.
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" initialize="buildcombo();">
           <mx:Script>
              <![CDATA[
                  [Bindable] public var MyOptions:Array = new Array();
              private function buildcombo():void
                  MyOptions.push({
                  label:"-SELECT-", data:0
                  for(var i:int=1;i<10;i++)
                  MyOptions.push({
                  label:"OPTION " + i, data:i.toString()
              private function reset():void
                  MyOptions = new Array();
                  buildcombo();
              private function ShowValue():void
                  trace(MyCombo.value);
          </mx:Script>
          <mx:ComboBox id="MyCombo" x="325" y="145" dataProvider="{MyOptions}" change="ShowValue();"/>
          <mx:Button x="362" y="224" label="Reset" click="reset();"/>
      </mx:Application>
        • 1. Re: Combo box set selected text.
          BennyBeta Level 4
          Use the ComboBox's prompt property:
          <mx:ComboBox id="MyCombo" x="325" y="145" prompt="-SELECT-" dataProvider="{MyOptions}" change="ShowValue();"/>
          Let me know if that does the trick.
          Ben Edwards
          • 2. Re: Combo box set selected text.
            run,ryan! Level 3
                 <mx:Script>
                    <![CDATA[
                       var arr:Array = new Array();
                        arr.push({
                        arr.push({
                       MyOptions = arr;
                        buildcombo();
                        trace(MyCombo.selectedLabel);
                </mx:Script>
                <mx:ComboBox id="MyCombo" x="325" y="145" dataProvider="{MyOptions}" updateComplete="ShowValue()"/>
            </mx:Application>
            • 3. Re: Combo box set selected text.
              cputnam14 Level 1
              Ben, That is a good thing to know, but it doesn't set the value on the select.
              Ryans solution works...I am just wondering why that makes a difference.
              • 4. Re: Combo box set selected text.
                run,ryan! Level 3
                1, "change" is event triggered by user interaction, not programmatically
                2, you don't have 'value' in your dp, only label
                3, as your dp is bindable, use a temp var when changing it, otherwise cost more resource
                • 5. Re: Combo box set selected text.
                  cputnam14 Level 1
                  I just used change for this example...the actual application is much more complex...when a user selects something from the drop down, a webservice gets fired and the result populates another drop down.
                  i have data in my dataprovider...thats what gets traced back.
                  I still don't understand why doing a push to the dp array causes the text to not show up by default, but doing a push to a temp variable and then setting the dp = to the temp variable does cause the text to show up.
