I use RH7 and want to know if there is a way you can import an entire RH project into another project. I know you can merge projects, but I want to combine 4 projects into one and then apply conditional builds.
If ProjectOne is going to hold all four, create the folders you need in that project. Then import from each project. You can select all the files in a folder but that is as good as it gets. You cannot import a folder and all sub-folders.
Style sheets and images and the CSS files will all be imported as well.
TOC and index need to be recreated. It is possible to amalgamate those using a text editor if you are comfortable with that sort of "editing".
