7 Replies Latest reply on May 26, 2009 5:01 AM by kglad
    contact.php file for my XML, Flash based contact form
    supergrabbit Level 1
      I am trying to create a contact.php file for my XML, Flash based contact form.
      Anybody know some good tutorials Please introduce me !
      Amanda Nguyen
        • 2. Re: contact.php file for my XML, Flash based contact form
          Thanks for the great collection of tutorials, kglad-tFlgSg.
          Do you  know some tutorial where the contact form uses both XML and PHP ?
          Amanda Nguyen
          • 3. Re: contact.php file for my XML, Flash based contact form
            what purpose does the xml file serve for a contact form?
            • 4. Re: contact.php file for my XML, Flash based contact form
              I think that I should post the 2 .xml files here:
              structure.xml
              <?xml version="1.0" encoding="utf-8" ?>
              <contactFormStructure>
              <formItems>
                <item id="1" label="Name" required="true" />
              <item id="2" label="E-mail" required="true">
                <validator>EmailValidator</validator>
              </item>
                <item id="3" label="Message" required="true" />
              </formItems>
                </contactFormStructure>
              configuration.xml
              <contactFormConfiguration>
              <emailTo>amanda099@gmail.com</emailTo>
              <serverProcessorType>php</serverProcessorType>
              <serverProcessorFileName>contact</serverProcessorFileName>
              <validateRequiredOnly>false</validateRequiredOnly>
              <submitFormOnEnter>true</submitFormOnEnter>
              <messageSentText>Thank you for your message.</messageSentText>
              <messageSentFailedText>The form is not submitted.</messageSentFailedText>
              <formProcessingText>processing...</formProcessingText>
              <plainText>false</plainText>
              <emailFromSource>2</emailFromSource>
              <subjectSource>Contact Form from your site</subjectSource>
              <validationErrorMessages>
              <message type="fieldIsRequired">{LABEL} is required.</message>
              <message type="emailNotValid">{LABEL} - is not valid email address.</message>
              <message type="minCharsLimitError">{LABEL} - The specified number of characters in a field is less
              than a required minimum.</message>
              <message type="reqExpError">{LABEL} - The specified string does not match with the regular
              expression.</message>
              <message type="biggerThanMaxError">{LABEL} - The specified number is greater than an acceptable
              biggest number for this field.</message>
              <message type="lowerThanMinError">{LABEL} - The specified number is lower than an acceptable
              lowest number for this field.</message>
              <message type="notANumberError">{LABEL} - The data is not a number.</message>
              <message type="negativeError">{LABEL} - The specified number must not be negative.</message>
              <message type="minRequirementError">{LABEL} - The minimum number of variants is not
              selected</message>
              <message type="maxRequirementError">{LABEL} - The number of variants selected exceeds the
              maximum</message>
              <message type="shouldBeEqualError">{LABEL} - values do not match</message>
              <message type="dateIsNotValidError">{LABEL} - date has wrong format</message>
              </validationErrorMessages>
              </contactFormConfiguration>
              I am working and learning and I would like to create the contact.php for my contact form.
              Please help !
              Amanda
              • 5. Re: contact.php file for my XML, Flash based contact form
                you might be totally confused or you might be doing two things with which you need help.
                why are you using those xml files?  a reasonable answer might be that you want to create a dynamic contact form.  but that's pretty unusual.  there's nothing difficult about that, but it requires you to learn a 2nd group of things, in addition, to using flash and php.
                and are you using as2 or as3?
                • 6. Re: contact.php file for my XML, Flash based contact form
                  Kglad !
                  I think that I should do more investigation before I can make myself  understandable
                  You said that:
                  '.........., but it requires you to learn a 2nd group of things, in addition, to using flash and php.'
                  What's 'a 2nd group of things'  ?
                  I am using as3.
                  Amanda
                  • 7. Re: contact.php file for my XML, Flash based contact form
                    1.  how to use flash and php
                    2.  how to use flash and xml
                    they are two different topics that aren't related to each other.
