3 Replies Latest reply on May 26, 2009 11:24 AM by Gregory Lafrance
    problem with backgroundColor in AdvancedDataGridColumn
    tcflex
      Hi All,
      I have a advancedatagrid with advanced data grid columns in it. each column item should have a specific back ground color depending upon the condition.
      If none of the condition satisfies it should reatin its default back ground color(i..e white and gray). I had used a style function and item render to paint the colore back ground on advance data grid column. This works fine when the conditions are met..but none of the conditions are met then it paints the data grid corresponding column to black, where it should retain white or grey default grid column colors(expected). If none of the conditions are met then I retun a null. please help.
      Thanks & Regards,
      tc.
