2 Replies Latest reply on May 24, 2009 9:31 AM by DHTVP
    passing arguments to PopUp
    Mohd Fayaz Level 1
      Hi all,
      How can we pass arguments(like strings, array etc.) to PopUp window. I am using TitleWindow class to create PopUp.
        • 1. Re: passing arguments to PopUp
          Michael Borbor Level 4
          If your component that you are goung to use as a PopUp declare a variable as public and it'll be accesible from your parent app.
          • 2. Re: passing arguments to PopUp
            DHTVP
            From the parent, you can call the PopUp with something like this:
            public var yourvariable:String = "Hello!";
            public function callPopup():void {
                var thePopUp:YourPopUp = PopUpManager.createPopUp(this, YourPopUp, true) as YourPopUp;
                //you can set the popups title with this if you want
                thePopUp.title = "Some Title";
                //here you send a variable to the popup
                thePopUp.varInPopUp = yourvariable;
                //style the popup if you want
                thePopUp.setStyle("borderAlpha", 0.9);
                //center the popup
                PopUpManager.centerPopUp(thePopUp);
            Then in your TitleWindow, simply declase the varInPopUp like this:
            [Bindable]
            public var varInPopUp:String;
            Then you can simply use it in the TitleWindow.
