7 Replies Latest reply on May 25, 2009 3:22 PM by Francisc
    Deserate for an Answer Trace()
    Schlamazel Level 1
      Why in the world am I not able to pass the variable daStuff to the trace() function? When I do that and use the debug button I get an error. I have properly set up the mm.cfg and located it in the proper folder. daStuff does properly display the passed variable content of "Best" in the Label.
      The only time i get the trace() to pass anything without an error is if I directly enter a string expression not passed by a variable containing a string.
      If I start with an Action Script project file then trace woorks just fine but it does not work in a Flex 3 project swf file!
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical">
      <mx:Script>
          <![CDATA[
          [Bindable]
          private var daStuff:String = "Best";
      </mx:Script>
      //the following does not pass string "Best" passed to it above.
      trace(daStuff);
      <mx:Label id="DestinationLabel" text="{daStuff}"/>
      </mx:Application>
