0 Replies Latest reply on Sep 22, 2008 3:45 PM by Balance
    Safest way to populate PDF form
    Balance Level 1
      I'm looking at using the CFPDFForm tag to populate a PDF with sensitive information. I know that I can pull the data from an XML file or from the db, but was wondering what most of you use (and why). Also, is it possible to encrypt the data with either method? And...is it possible for a user to save the PDF to his/her local drive, disconnect from the Web, and still save the PDF? I'm not sure if the PDF would (automagically) try to connect to the web upon the user submitting the PDF form. Thanks for any insight.
