13 Replies Latest reply on May 24, 2009 3:03 PM by kglad
    How to add description tag
    tseyigai Level 1
      Hello,
      I have an xml file that loads the pictures, but I want to add a description tag for each picture. Below is the xml file for this. Can anyone help me add a description tag that would work?
      Tseyigai
      <?xml version="1.0" encoding="UTF-8"?>
      <galleries>
      **    Please read this information to learn how to add more galleries to your website.
      **    Here are all the galleries that you can use for the website pages. Each gallery has
      **    an index or ID. With the help of index the gallery can be connected with the definite
      **    website page with gallery type. Also this page must have galleryID which should be equal
      **    to the gallery index in this file.
      **    Each gallery consists of the list of images. Each image has and url parameter and also
      **    width and height parameters that define dimensions of the box for the image.
      **    It is recommended to use an XML editor to make changes to this file because it’s less
      **    possible to make an error in the markup which can cause a not working website.
      **    The recommended size for image_icon=333x333 px.
      <gallery id="1" name="nature">
      <image image_icon="22598_nature_icon_15.jpg" image="22598_nature_b_15.jpg"/>
      <image image_icon="22598_nature_icon_14.jpg" image="22598_nature_b_14.jpg"/>
      <image image_icon="22598_nature_icon_13.jpg" image="22598_nature_b_13.jpg"/>
      <image image_icon="22598_nature_icon_12.jpg" image="22598_nature_b_12.jpg"/>
      <image image_icon="22598_nature_icon_11.jpg" image="22598_nature_b_11.jpg"/>
      <image image_icon="22598_nature_icon_10.jpg" image="22598_nature_b_10.jpg"/>
      <image image_icon="22598_nature_icon_1.jpg" image="22598_nature_b_1.jpg"/>
      <image image_icon="22598_nature_icon_2.jpg" image="22598_nature_b_2.jpg"/>
      <image image_icon="22598_nature_icon_3.jpg" image="22598_nature_b_3.jpg"/>
      <image image_icon="22598_nature_icon_4.jpg" image="22598_nature_b_4.jpg"/>
      <image image_icon="22598_nature_icon_5.jpg" image="22598_nature_b_5.jpg"/>
      <image image_icon="22598_nature_icon_6.jpg" image="22598_nature_b_6.jpg"/>
      <image image_icon="22598_nature_icon_7.jpg" image="22598_nature_b_7.jpg"/>
      <image image_icon="22598_nature_icon_8.jpg" image="22598_nature_b_8.jpg"/>
      <image image_icon="22598_nature_icon_9.jpg" image="22598_nature_b_9.jpg"/>
      </gallery>
      </galleries>
      Edit/Delete Message Reply With Quote Quick reply to this message
        • 1. Re: How to add description tag
          <galleries>
          <image description="whatever" image_icon="22598_nature_icon_14.jpg" image="22598_nature_b_14.jpg"/>
          <image description="whateverelse" image_icon="22598_nature_icon_13.jpg" image="22598_nature_b_13.jpg"/>
          <image description="etc" image_icon="22598_nature_icon_12.jpg" image="22598_nature_b_12.jpg"/>
          </gallery>
          </galleries>
          • 2. Re: How to add description tag
            tseyigai Level 1
            thanks but that doesn't seem to work when adding a descript. tage like that:
            <image description="whatever" image_icon="22598_nature_icon_15.jpg" image="22598_nature_b_15.jpg"/>
            *I added the tag in red above, but no pictures would load then. Obviously, I was also adding the other image tags as well.
            Is there another way to add a description tag that would work correctly?
            Tseyigai
            • 3. Re: How to add description tag
              did you change something in the actionscript that parses the xml?
              • 4. Re: How to add description tag
                tseyigai Level 1
                No...I don't think so....
                I've tried and tried, several different ways, and it either won't load the images or it would load, but there wasn't a description of the images.
                *Could you possibly just add a very simple description tag for each image and then I'll try again?
                I've also tried: descrip="whatever" image_icon="22598_nature_icon_15.jpg" image="22598_nature_b_15.jpg"/>
                with no anchor tag at the beginning, and this will load the images, but there's no description.
                *I really some help with this.
                Tseyigai
                • 5. Re: How to add description tag
                  if you used the encoding i gave, your images would load without problem.  of course, no description will appear in the swf unless you add code to parse the description parameter.
                  if your images don't load, you probably have a malformed xml file.  copy and paste the code from the xml file you created that uses the code i suggested.
                  • 6. Re: How to add description tag
                    tseyigai Level 1
                    *I just added the simple description tags to the first 3 image tags below. Underneath this gallery xml page is the other xml page for the main document.
                    <galleries>
                    <image image_icon="22598_nature_icon_15.jpg" image="22598_nature_b_15.jpg "/>
                    </gallery>
                    </galleries>
                    Below is the main xml file:
                    <website>
                          **    Please read this information to learn how to tune your website just using this XML file.
                          **    With the help of this file you can change any text or image in the template, add new pages,
                          **    creating them on the basis of any of the existing layouts — splash page, gallery, about page,
                          **    contacts or readmore page.
                          **    It is also easy to change any sound and music in the template as everything is stored in the
                          **    form of mp3 files, to do this simply replace an mp3 file with your own.
                          **    New template engine supports events — page changeover and external URL activation. This means
                          **    that now it is possible to manage site contents more softly, activating the events or at pressing
                          **    pictures, or links in the text, or menu or any other buttons. To activate the event on pressing
                          **    the button or picture use click paramerer, in which the event name is being written - switchPage
                          **    or getURL and parameters after comma. For instance click="switchPage,5" means migration to the page
                          **    with index 5, and click="getURL,http://www.website.com,_blank" — opening of the new page in a new
                          **    window. To activate the events directly from the text, i.e. to make the links active, use HTML.
                          **    To activate a text area as a link, write for instance <a href="event:switchPage,8">PRIVACY POLICY</a>
                          **    migration to the page with index 8. If you need to open a definite readmore page, than you should
                          **    state page index number with readmore type ( type="readmore" ) as the first parameter, and as the
                          **    second parameter, after comma an index readmore block number should be stated, for instance switchPage,7,1,
                          **    under the condition that the page with index 7 possesses readmore type, and this page with readmore
                          **    block information under index 1 will open.
                          **    Events add great opportunities in template management. Create new pages, galleries and refer them from
                          **    anywhere using the events. If the given material on events appeared to be a bit complicated for you,
                          **    view the examples in the given file, this will help you to master the technique of events activating quickly.
                          **    More detailed description of opportunities and functionality of the template can be found near each section
                          **    of this file.
                          **    It is recommended to use an XML editor to make changes to this file because it’s less possible to make
                          **    an error in the markup which can cause not working website.
                          **    General Settings
                          **    Here you can change general settings of the template - company name, slogan and text in the bottom, where
                          **    copyright is placed by default.
                        <settings>
                            <logo><![CDATA[<a href="event:switchPage,0">CANUTOSKY.COM</a>]]></logo>
                            <slogan>LA NUEVA GENERACION PARA JEHOVÁ</slogan>
                            <copyright><![CDATA[JOHN BROWN  (C) 2009  |<font color="#ffffff"><a href="event:switchPage,3">  PRIVACY POLICY</a>  <font color="#414141">|</font>  <a href="event:switchFullScreen">FULLSCREEN</a></font>]]></copyright>
                        </settings>
                          **    Menu
                          **    Here you can change menu buttons names, and with the help of the parameter targetPage to state the page,
                          **    on which the given button will refer to. If you need to activate the event on pressing the menu button,
                          **    for instance to open site in the new window, you can use click parameter, for instance
                          **    <item click="getURL,http://www.website.com,_blank"><![CDATA[GALLERIES]]></item>
                        <menu>
                            <item targetPage="0"><![CDATA[<font color="#545454">HOME PAGE</font>]]></item>
                            <item targetPage="1"><![CDATA[<font color="#545454">ABOUT ME</font>]]></item>
                            <item targetPage="2"><![CDATA[<font color="#545454">CONTACTS</font>]]></item>
                        </menu>
                          **    Sounds
                          **    Here all sounds present in the template are described. Each sound has an id, which can’t be modified.
                          **    You can change the path to mp3 file. With the help of other parameters you can change parameters of the
                          **    given sound playback. Loops parameter indicates the quantity of repetition. With the help of volume you
                          **    can specify loudness, which changes from 0 to 100, where 100 is the highest boundary.
                          **    Panning replaces balance, and with the help of the additional parameters skipFrom and skipTo beginning
                          **    and ending of the given track is being specified in miliseconds. Basically this serves for escaping pauses
                          **    at loops playback, as mps format saves service information in the beginning of the track or in the end of it.
                        <sounds>
                            <sound id="templateBackgroundMusic" url="22598_templateBackgroundMusic.mp3" loops="9999" volume="100" panning="0" skipFrom="23" skipTo="42811"/>
                            <sound id="topMenuButtonSound" url="22598_topMenuButtonSound.mp3"/>
                            <sound id="pageImageSound" url="22598_pageImageSound.mp3"/>
                            <sound id="pagesSwitchingSound" url="22598_pagesSwitchingSound.mp3"/>
                            <sound id="pagesAppearenceSound" url="22598_pagesAppearenceSound.mp3"/>
                            <sound id="pageButtonSound" url="22598_pageImageSound.mp3"/>
                            <sound id="galleryImageSound" url="22598_pageImageSound.mp3"/>
                            <sound id="galleryOpenSound" url="22598_galleryOpenSound.mp3"/>
                        </sounds>
                          **    Pages
                          **    Here all pages present in the template are described. Each page has its serial number, which is given automatically,
                          **    depending on pages order in the file. The first page has serial number 0, the second — 1 etc.
                          **    Each page has the type, which is stated in type parameter. The type defines page layout. There can be 5 and
                          **    more layout types in the template on default.
                          **    The page can have other parameters, for instance at 3D engine usage, it is possible to specify page coordinates
                          **    and angle of rotation in space.
                          **    Inside the page tag, images and texts used in it are describes, along with other additional elements such as buttons
                          **    and forms. For managing of events on images and buttons use click parameter, standard tag for the text is HTML - <a>.
                          **    More detailed events logic is described in the beginning of this document.
                          **    The inner content of some pages types can not be specified, for example gallery and readmore pages. Such pages are
                          **    called dynamic and get their content from without. For example readmore page downloads a certain content from
                          **    ReadMorePages section, and gallery page is connected with galleries.xml file, where it finds gallery contents at
                          **    the stated galleryID.
                        <pages>
                            <!-- 0 -->
                            <page type="gallery" galleryID="1"/>
                            <!-- 1 -->
                            <page type="about">
                                <images>
                                    <image url="22598_about_me_Pic_1.jpg" click="switchPage,4,1"/>
                                </images>
                                <texts>
                                    <text><![CDATA[About me]]></text>
                                    <text><![CDATA[SED UT PERST UNMNISAS DELER KRTASEA NTE KERTSDERA:]]></text>
                                    <text><![CDATA[Fusce feug maleoas orbim nsecpiscing elit lerode fersae dekera veronr gerts. Cum socis mia atoque pena tikertderos nt monlase orem ipsum dolor sit amet, consectetuer adipiscing]]></text>
                                    <text><![CDATA[<li><a href="asfunction:link">Fusce feug maleoas orbim secpiscing</a></li>]]></text>
                                    <text><![CDATA[<li><a href="asfunction:link">Elit lerode fersae Dekera veronr gerts</a></li>]]></text>
                                    <text><![CDATA[<li><a href="asfunction:link">Dekera veronr gertsum socis mia natoque</a></li>]]></text>
                                    <text><![CDATA[<li><a href="asfunction:link">Pena tikertderos nt monlase orem ipsum</a></li>]]></text>
                                </texts>
                                <buttons>
                                    <button click="switchPage,4,0"><![CDATA[more info]]></button>
                                </buttons>
                            </page>
                            <!-- 2 -->
                            <page type="contacts">
                                <images>
                                    <image url="22598_contact_me_Pic_1.jpg" click="switchPage,4,2"/>
                                </images>
                                <texts>
                                    <text><![CDATA[Contact form]]></text>
                                    <text><![CDATA[SED IN LACUS UT ENIM ADIPISCING ALIQUET.]]></text>
                                </texts>
                                <buttons>
                                    <button click="onFormReset"><![CDATA[reset]]></button>
                                    <button click="onFormSubmit"><![CDATA[submit]]></button>
                                </buttons>
                                <form configuration="22598_formConfiguration.xml">
                                    <items>
                                        <item label="Name">Name:</item>
                                        <item label="Email">E-mail:</item>
                                        <item label="Phone">Fax:</item>
                                        <item label="Message">Message:</item>
                                    </items>
                                </form>
                            </page>
                            <!-- 3 -->
                            <page type="simple" closeButton="true">
                                <texts>
                                    <text><![CDATA[Privacy policy]]></text>
                                    <text><![CDATA[SED UT PERSPICIATIS UNDE OMNIS ISTE NATUS.]]></text>
                                    <text><![CDATA[Lorem ipsum dolor sit amet, consectetur adipiscing elit. Phasellus posuere, lacus vitae malesuada porttitor, mi ligula lacinia nisl, tempus auctor orci libero in libero. Nunc sit amet nibh quis purus dignissim sollicitudin. In hac habitasse platea dictumst. Duis congue lacus. Proin volutpat justo sit amet felis. Nullam hendrerit. Curabitur eget risus in augue auctor aliquet. Suspendisse accumsan molestie ante. Etiam eu lorem ac massa posuere faucibus. Aenean erat. Morbi ante. Morbi imperdiet velit eget erat. Vestibulum porttitor nisl id enim. Duis at lectus eget lorem volutpat egestas. Proin nulla augue, dapibus sed, eleifend in, rutrum at, metus.]]></text>
                                </texts>
                                <buttons>
                                    <button click="getURL,mailto:info@companyname.com,_blank"><![CDATA[info@companyname.com]]></button>
                                </buttons>
                            </page>
                            <!-- 4 -->
                            <page type="readmore" closeButton="true"/>
                        </pages>
                          **    ReadMore Pages
                          **    Very often all information can't be placed in the standard page layout, that's why there are links to ordinary
                          **    text pages - readmore pages from such pages. There can be added any number of such pages in the given section.
                          **    Use the events logic to make links in the text to external sites or other pages. More detailed events logic is
                          **    described in the beginning of this document.
                        <readMorePages>
                            <!-- 0 -->
                            <page>
                                <texts>
                                    <text><![CDATA[Read More 1]]></text>
                                    <text><![CDATA[Lorem ipsum dolor sit amet, consectetur adipiscing elit. Phasellus posuere, lacus vitae malesuada porttitor, mi ligula lacinia nisl, tempus auctor orci libero in libero. Nunc sit amet nibh quis purus dignissim sollicitudin. In hac habitasse platea dictumst. Duis congue lacus. Proin volutpat justo sit amet felis. Nullam hendrerit. Curabitur eget risus in augue auctor aliquet. Suspendisse accumsan molestie ante. Etiam eu lorem ac massa posuere faucibus. Aenean erat. Morbi ante. Morbi imperdiet velit eget erat. Vestibulum porttitor nisl id enim. Duis at lectus eget lorem volutpat egestas. Proin nulla augue, dapibus sed, eleifend in, rutrum at, metus.<br/><br/>Lorem ipsum dolor sit amet, consectetur adipiscing elit. Phasellus posuere, lacus vitae malesuada porttitor, mi ligula lacinia nisl, tempus auctor orci libero in libero. Nunc sit amet nibh quis purus dignissim sollicitudin. In hac habitasse platea dictumst. Duis congue lacus. Proin volutpat justo sit amet felis. Nullam hendrerit. Curabitur eget risus in augue auctor aliquet. Suspendisse accumsan molestie ante. Etiam eu lorem ac massa posuere faucibus. Aenean erat. Morbi ante. Morbi imperdiet velit eget erat. Vestibulum porttitor nisl id enim. Duis at lectus eget lorem volutpat egestas. Proin nulla augue, dapibus sed, eleifend in, rutrum at, metus.]]></text>
                                </texts>
                                <buttons>
                                    <button click="switchPage,4,1"><![CDATA[read more]]></button>
                                </buttons>
                            </page>
                            <!-- 1 -->
                            <page>
                                <texts>
                                    <text><![CDATA[Read More 2]]></text>
                                </texts>
                                <buttons>
                                </buttons>
                            </page>
                            <!-- 2 -->
                            <page>
                                <texts>
                                    <text><![CDATA[Read More 3]]></text>
                                </texts>
                                <buttons>
                                </buttons>
                            </page>
                        </readMorePages>
                    </website>
                    • 7. Re: How to add description tag
                      your first error is in the 2nd red line.  you failed to close the image node:
                      <galleries>
                      should be:
                      <galleries>
                      • 8. Re: How to add description tag
                        tseyigai Level 1
                        Oh well, it now displays the first image "twice" and won't load a description.
                        This code:
                        --><gallery id="1" name="nature">
                        • 9. Re: How to add description tag
                          you have that image listed twice.  so, it's going to load twice.
                          and like i said, a description won't appear in the swf unless you add code to
                          1.  parse that attribute and
                          2.  create a textfield in which to display the description and
                          3.  assign the textfield's text property  to that attribute's value.
                          • 10. Re: How to add description tag
                            tseyigai Level 1
                            Ok, but I dont know "how to do those things."
                            (Can you give me an example "exactly" that would apply to the document at hand?)
                            and what would the description tag look like then for #15 image so that it wouldn't load the image twice?
                            (I need the "exact" code. I'm a little new to this.)
                            Tseyigai
                            • 11. Re: How to add description tag
                              can you find the code that parses the xml in your current fla?
                              and use the xml encoding i suggested.  it's not loading the same file twice.  all i did was take your current xml file and add an attribute
                              description="..."
                              inside the image tags.
                              • 12. Re: How to add description tag
                                tseyigai Level 1
                                I don't have the fla. just the swf
                                You said:
                                description="..."
                                inside the image tags. However, when you showed me your example it wasn't inside the original image tags it was below it in its own anchor.
                                <image description="whatever"/>
                                *I guess I give up. Thanks anyway, but unless I get it to work, I don't know what else to do here.
                                It seems like we could get this to work though.
                                *I've enclosed all the files here for you to look. Could you please look them over and see what you could do
                                especially with the gallery xml file? It's flash CS3
                                Tseyigai
                                • 13. Re: How to add description tag
                                  if you don't have the fla, you can't add a new feature to that swf.
                                  you could decompile the swf to create a fla but that might not be legal.
