1 Reply Latest reply on May 27, 2009 4:59 AM by *Prashant Shelke*
    Show precission (.00) in OLAP DataGrid
    Varun Bajaj (PHP)
      I need to display precission value in OLAP dataGrid basically (.00). I know mathamtically 2 and 2.00 are same but in a project i need to display 2.00 rather then 2. I am using OLAP dataGrid.
      any help is heartly welcome.
      thanks in advance,
      Varun Bajaj
        • 1. Re: Show precission (.00) in OLAP DataGrid
          *Prashant Shelke* Level 4
          I think you have to go for NumberFormatter & labelFunction(can be applied on any dataGridColumn you want)
          <mx:NumberFormatter id="numberFormatter" precision="2" /> <!-- here number formatter defined -->
          <mx:DataGridColumn labelFunction="formatAmount" .... />
          public function formatAmount(value:Object,column:DataGridColumn)  : String /** this function you have to call as labelFunction **/
              try
                  /* value is nothing but column data, in your case 2 which we have to show as 2.00
                  if(value != null && value != "" || value != "-")
                      return numberFormatter.format(value);
                  else
                      return "-";
              catch(error : Error)
                  Alert.show("error : "+error.getStackTrace());
              return "";
          OR
          you have to iterate a data & need to process each amount under numberformatter
          Thanks.
