2 Replies Latest reply on May 25, 2009 5:09 AM by yancaoshi
    One question about data binding
    yancaoshi
      Hi all,
      Data binding is easy to use when developing. I often define new property with public directive, but I find I can't control the processing when property value changes. I learned that there's a propertyChange event when the bindable property changes. If a property is set to 29, and I want it to be ceiled to 30 in the background. How can I achieve this?
        • 1. Re: One question about data binding
          BennyBeta Level 4
          Hi yancaoshi.  I'm not sure if I understand the question, so if I miss just let me know.
          You can change the value a property is set to when it is set using get/set functions.
          private var _value:Number = 0;
          [Bindable]
          public function set value( v:Number ):void
               _value = v;
          public function get value():Number
               return _value;
          A regular get/set setup looks something like the above code.  It creates a property called "value" that can be accessed just as if it were declared as a public var.  The difference is that you can add some logic to the set function.
          [Bindable]
               // silly logic to raise 29 to 30
               if( v == 29 ) {
                    _value = 30
               } else {
                    _value = v;
          Now when someone calls the below code, the value of the "value" property is actually set to 30 and anyone "binded" to that property will get the value 30.
          The following documentation may prove helpful:
          http://www.flexafterdark.com/docs/ActionScript-GetSetFunctions
          http://www.flexafterdark.com/docs/Flex-Binding
          Let me know if that helps at all.
          Ben Edwards
          • 2. Re: One question about data binding
            yancaoshi Level 1
            Hi Edwards,
            Your answer is very helpful. But is it possible to override propertyChange method, and give me an example as well.
            Best wishes,
            yancaoshi
