7 Replies Latest reply: May 25, 2009 10:39 AM by kglad RSS
    Antialiasing of images in rotated dynamically loaded HTML
    Ziggizag Community Member
      Hi guys,
      Flash CS3, Action Script 3
      I have some nasty issue. I need to display dynamically loaded HTML document with images but my designer wants the document to be presented in angular (slopy) manner rather than simply vertically placed on stage. HTML document is loaded inside a .htmlText property of a textField.
      While the texts itself renders perfectly with embedded fonts and "AntiAlias for readability" I have a huge problem with images inside  HTML. For whatever reason they look nasty aliased - complete disaster:
      Is there any way to get better quality in this case? Any ideas?
      Rgs,
      Ziggi
        • 1. Re: Antialiasing of images in rotated dynamically loaded HTML
          kglad CommunityMVP
          1.  paste the code you using to load the htmlText and
          2.  paste the htmlText
          • 2. Re: Antialiasing of images in rotated dynamically loaded HTML
            Code to load external files and parse them into Flash environment:
            var loadType:String;
            loadType = "styl";
            loadFile("styles/style.css");
            function loadFile(url):void{
                var request:URLRequest=new URLRequest();
                request.url=url;
                var loader:URLLoader=new URLLoader();
                addListeners(loader);
                try{
                    loader.load(request);
                }catch(e:Error){
                    tekst.text = "File loading error!";
                    removeListeners();
            function addListeners(d:IEventDispatcher):void{
                d.addEventListener(Event.COMPLETE, onComplete);
                d.addEventListener(IOErrorEvent.IO_ERROR, ioErrorHandlingFunction)
            function onComplete(e:Event):void{
                var loader:URLLoader=URLLoader(e.target);
                if(loadType=="styl"){
                    var css:StyleSheet = new StyleSheet();
                    css.parseCSS(loader.data);
                    tekst.styleSheet = css;
                    loadType = "body";
                    loadFile("texts/html.txt");
                }else if(loadType=="body"){
                    tekst.htmlText = loader.data;
                removeListeners();
            function ioErrorHandlingFunction(e:IOErrorEvent):void{
                removeListeners();
            function removeListeners():void{
                removeEventListener(Event.COMPLETE, onComplete);
                removeEventListener(IOErrorEvent.IO_ERROR, ioErrorHandlingFunction);
            HTML file:
            <H1>Blah blah blah blah</H1>
            <H2>Blah blah blah blah</H2>
            <textformat leading="122"><img src="images/pool.jpg" width="220" height="163" vspace="-20" hspace="40"></textformat>
            <p>Blah blah blah blah</p>
            CSS file:
            H1{
            font-size:16;
            color: #CD0303;
            leading:-20;
            H2{
            font-size:14;
            color: #000000;
            leading:-4;
            p{
            font-size:11;
            color: #000000;
            • 3. Re: Antialiasing of images in rotated dynamically loaded HTML
              kglad CommunityMVP
              change your onComplete() function and add an imageLoadCompleteF() to your a.s.:
                      loadType = "body";
                      loadFile("html.txt");
                        var ldr:Loader = Loader(tekst.getImageReference("image"));
                        ldr.contentLoaderInfo.addEventListener(Event.COMPLETE,imageLoadCompleteF);
                  removeListeners();
              function imageLoadCompleteF(e:Event){
                   Bitmap(Loader(tekst.getImageReference("image")).content).smoothing = true;
              and add an id attribute to your img tag:
              <img height="163" hspace="40" id="image" src="image1.jpg" vspace="0" width="220" />
              • 4. Re: Antialiasing of images in rotated dynamically loaded HTML
                Well,
                I appreciate - this is indeed working. Please notice some minor faults in your scripts (probably this text editor messed the script):
                it should read:
                and
                So, it is clear now the images dynamically loaded can be smoothed but - as the content is dynamic and there may be more than one image of uncertain id - how to get all the id references to images in loaded html file - can you be so kind and answer this question too?
                Best regards,
                Ziggi
                • 5. Re: Antialiasing of images in rotated dynamically loaded HTML
                  kglad CommunityMVP
                  you can find the id by parsing the htmlText using the flash string methods.
                  • 6. Re: Antialiasing of images in rotated dynamically loaded HTML
                    Thank you!
                    You were indeed very helpful - I may go on now
