6 Replies Latest reply on May 26, 2009 12:39 PM by Flex harUI
    ItemRenderer and drag and dropping...
    rckehoe
      I have two mx:list controls.... Both use the ItemRender functionality to display custom data in the list...
      ListA and ListB
      I enabled the dragging and dropping functionaity between the two list boxes and this works as expected...
      When I used the dragDrop funtion on ListB, I am calling a function that looks like this...
      private function UpdateSelectedDirs(event:DragEvent):void {
                /// Data Here
      How do I obtain the information from the selected object that was dragged?
      The ItemRender defines a field called title and another field called path...
      Is there any way to access this information when the object is dragged from ListA and dropped into ListB?
      I tried this with no luck:
      var ObjectPath:String = event.dragSource.dataForFormat('path') as String;
      Should that work for me?
        • 1. Re: ItemRenderer and drag and dropping...
          Flex harUI Adobe Employee
          I'd try:
               event.dragInitiator.selectedItem.path
          This might also work:
          var ObjectPath:String = event.dragSource.dataForFormat("items").path as String;
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: ItemRenderer and drag and dropping...
            rckehoe Level 1
            Neither of the 2 worked for me....
            This produced an error for me...
            I belive it's because the selectedItem resource is not able to be called with event:DragEvent as the handler.
            Any other options?
            • 3. Re: ItemRenderer and drag and dropping...
              Well, that's the correct general principle but the actual code will depend on your circumstances, such as:
              - What do your dataProvider items look like?  Regular objects or instances of classes?
              - Did you get an exception dialog or nothing?  If you got an exception post the full stacktrace
              You can do some diagnostics by adding a Label that binds to the source List's selectedItem and/or its .path property so you can see what the source List thinks is selected, if anything.
              Alex Harui
              Flex SDK Developer
              Adobe Systems Inc.
              • 4. Re: ItemRenderer and drag and dropping...
                rckehoe Level 1
                This is the erro that I get when I use:
                var Path:String = event.dragInitiator.selectedItem.path;
                The error is:
                1119: Access of possibly undefined property selectedItem through a reference with static type mx.core:IUIComponent.
                The whole function looks like this:
                        trace(Path);
                I have 2 mx:lists that look like this:
                <mx:List x="0" y="48" width="361" height="220" itemRenderer="FTP_Listing_ItemRender" id="DIRLIST_PATH" dragEnabled="true">
                     <mx:dataProvider>{_SERV_GetDirectoryListing.lastResult.root.directory}</mx:dataProvider>
                </mx:List>
                <mx:List x="369" y="48" width="212" height="220" id="backup_list" dropEnabled="true" itemRenderer="FTP_Listing_ItemRender" dragDrop="UpdateSelectedDirs(event);"></mx:List>
                I have an httpservice that gets an XML document with information and populates the first List box as you can tell.
                Now what am I doing wrong?
                • 5. Re: ItemRenderer and drag and dropping...
                  rckehoe Level 1
                  In case anyone is interested... If found out a solution to my problem...
                  Here is the code that I used:
                  var ObjArray:Array = event.dragSource.dataForFormat('items') as Array;
                  var Path:String = ObjArray[0].path;
                  Alert.show(Path);
                  • 6. Re: ItemRenderer and drag and dropping...
                    Ah, yes.  I would try this:
                    var Path:String = List(event.dragInitiator).selectedItem.path;
                    Make sure you import mx.controls.List in your script block.
                    Alex Harui
                    Flex SDK Developer
                    Adobe Systems Inc.
