5 Replies Latest reply on May 25, 2009 11:16 PM by FlexHelpNeeded
    Flex Image Gallery Help needed
    FlexHelpNeeded
      Hey Guys..
      So I am totally new to Flex / PHP / SQL. I am doing this for a small task. Basically there is a SQL server containing details of images and location information. Using Flex 3 we need to get details from the server and post them like a image gallery. We can use anything like datagrid , HBox etc..
      Now I have a query written which spits data back in XML format for all the images.
      The format of the coming back XML is something like
      <images>
      <location>.....</location>
      <name>Nameof Pic </name>
      <caption>captionofpic</caption>
      </images>
      Now my question is
      1) How do I populate these images in a datagrid or hbox etc.. I have no clue how to get this data and put them into use.. tried a lot of search but everything is so complicated. Looking for the simplest solution. does not matter how it looks..
      More questions are after i fix this
      thanks a lot
        • 2. Re: Flex Image Gallery Help needed
          FlexHelpNeeded Level 1
          Michael Borbor wrote:
          ARe you looking for something like this?
          http://www.adobe.com/devnet/flex/samples/photo_explorer/
          yeah something exactly like that.. but they are looking so complex in coding.. I need to do a very basic one.. can u please guide if possible
          There it is a XML file stored.. I have a XML file generated via PHP from SQL server.. I don't know how to apply this data coming back to make something like whats shown above
          thanks
          • 3. Re: Flex Image Gallery Help needed
            Michael Borbor Level 4
            I could help you but I'm gonna call it a night, folks at europe and asia should be on-line soon so they could help you, if they don't tomorrow I'll give you a hand. Meanwhile you can find great starting tutorials here
            http://learn.adobe.com/wiki/display/Flex/1d.+RIA+Tutorial.
            Good night.
            • 4. Re: Flex Image Gallery Help needed
              Good night.
              Thanks Michael
              It helped and I have made some scratch code from it. Now what I have done is
              create a button to call photos
              <mx:Button x="242" y="57" label="Load Photos" id="getphotos" click="browsephotos.send();"/>
              Then created a HTTPservice when the button is clicked
                <mx:HTTPService id="browsephotos" url="XXXXXX" method="POST" result="getphoto(event)">
                     <mx:request>
                         passing some stuff here
                     </mx:request>
                 </mx:HTTPService>
              The XML generated from this request is in the format
              <photos>
              <photoloc></photoloc>
              <caption></caption>
              </photos>
              Now to capture this data I have made a function called getphoto
                  private function getphoto(event:ResultEvent):void
                              feed = event.result.photos as ArrayCollection;
              feed is delacred previously as an array collection bindable
              Now my current question is
              1) Is it the right way to capture the XML data coming in ? I mean is the event.result.photos right???
              Also Now to display it I have done
              <mx:itemRenderer>
               <mx:Component>
                 <mx:VBox width="125" height="125" horizontalAlign="center">
                 <mx:Image width="75" height="75" source="????????" /> // should be from photoloc
                 <mx:Text text="????????" /> //should be from caption
                 </mx:VBox>
                </mx:Component>
               </mx:itemRenderer>
              Now How do i fill in the two sources mentioned there?? I don't know what the correct format is going to be??
              Thanks for all the help guys!!!
              • 5. Re: Flex Image Gallery Help needed
                Fixed it myself.. thanks guys!!!
