9 Replies Latest reply on May 26, 2009 10:38 PM by DM277
    Array Collection
    Seglespaan Level 1
      I'm using the following code in conjunction with amfPHP to pull information from a database, this info is then (as far as I know) returned to flex as an array collection.
      What I'm looking to do is populate the list with the data within the array collection,
      Heres my code
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init()">
          <mx:Script>
              <![CDATA[
                  import flash.net.*;
                  import mx.collections.ArrayCollection;
                  import mx.rpc.events.ResultEvent;
                  public function connect():Object
                      var gw:NetConnection = new NetConnection();
                      gw.connect("http://localhost/amfphp/gateway.php");
                      var res:Responder = new Responder(onResult, onFault);
                      function onResult(responds:Object):void
                        trace(responds.serverInfo.initialData[0][1]);
                      function onFault(responds:Object):void
                          for(var i in responds)
                              trace(responds[i]);
                      gw.call("Test.getRecordset", res);
                      return res;
                  public function init()
                      connect();
          </mx:Script>
          <mx:List x="75" y="113"></mx:List>
      </mx:Application>
        • 1. Re: Array Collection
          Seglespaan Level 1
          Forgot to say I can see the correct information has been passed to flex via the line
          just not sure how to access this outwith the connect function
          Cheers
          • 2. Re: Array Collection
            DM277
            Try the following solution.
                <mx:Script>
                    <![CDATA[
                        import flash.net.*;
                        private var arrResult:ArrayCollection = new ArrayCollection();
                               arrResult = responds.serverInfo.initialData;
                                    trace(responds[i]);
                            return res;
                            connect();
                </mx:Script>
                <mx:List x="75" y="113" dataProvider = "{arrResult }">
            <mx:itemRenderer>
            <mx:Component>
            <mx:VBox
            <mx:Label
            text="{data.Name}" />   //Here give the name of the value in the result
            </mx:VBox>
            </mx:Component>
            </mx:itemRenderer>
            </mx:List>
            </mx:Application>
            • 3. Re: Array Collection
              Seglespaan Level 1
              i have tried this changing the line
              text="{data.Name}"
              to text="{data.category}"
              but the list still appears blank
              Cheers
              • 4. Re: Array Collection
                Seglespaan Level 1
                i've managed to get the list populating by making the
                var arrResult bindable,
                but the list populates as
                1, field 1, field 2, field 3
                2, field 1, field 2, field 3
                3, field 1, field 2, field 3
                4, field 1, field 2, field 3
                5, field 1, field 2, field 3
                etc,
                is there a way i can get it just to select the second field to put in the list and ingnore the other data!
                • 5. Re: Array Collection
                  Michael Borbor Level 4
                  Use the labelField property like this labelField="field2"
                  • 6. Re: Array Collection
                    Seglespaan Level 1
                    thanks,
                    for some reason when i was using labelField="field1"
                    nothing was changing, bu when I changed this to
                    labelField="2"
                    i got the desired result.
                    Here's another question, is there a way of only placing this label in the list if it doesn't already exist?
                    similar to SELECT DISTINCT in mysql,
                    or am i better off doing this within mySQL and only returning the distinct category names?
                    • 7. Re: Array Collection
                      Better do it in MySQL you reduce bandwith consumption.
                      • 8. Re: Array Collection
                        Seglespaan Level 1
                        I've modified my code as follows,
                        the idea being that when the user selects a category from the list, the tile list is populated with the icons, I can get this to poulate with the icon reference but can't actually get the icons to appear. Also for some reason when i select business, the communications results come up and vice versa
                        <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" width="800" layout="absolute" creationComplete="init()">
                            <mx:Script>
                                <![CDATA[
                                    import flash.net.*;
                        [Bindable]
                                    private var categoryResult:ArrayCollection;
                        [Bindable]
                                    private var iconResult:ArrayCollection;
                                    public function getDistinct():Object
                                          categoryResult = new ArrayCollection(responds.serverInfo.initialData);
                                          //trace(arrResult);
                                                trace(responds[i]);
                                       gw.call("Test.getDistinct", res);
                                        return res;
                                    public function getIcons(cats:String):Object
                                    var gw2:NetConnection = new NetConnection();
                                        gw2.connect("http://localhost/amfphp/gateway.php");
                                        var res2:Responder = new Responder(onResult, onFault);
                                        function onResult(responds2:Object):void
                                          iconResult = new ArrayCollection(responds2.serverInfo.initialData);
                                          trace(iconResult);
                                        function onFault(responds2:Object):void
                                            for(var i in responds2)
                                                trace(responds2[i]);
                                       trace(cats);
                                       gw2.call("Test.getCategoryIcons", res2, cats);
                                       return res2;
                                        getDistinct();
                                        getIcons("business");
                                   public function changeIcons(cat)
                                   trace(cat);
                                   getIcons(cat);
                                   iconTiles.dataProvider = iconResult;
                                   iconTiles.labelField = iconResult[0];
                                   iconTiles.iconField = iconResult[0];
                            </mx:Script>
                        <mx:List id="categoryList"
                        width="150" x="75" y="113"
                        dataProvider = "{categoryResult}" labelField="1"
                        change="changeIcons(categoryList.selectedItem)" >
                        </mx:List>
                        <mx:TileList id="iconTiles"
                        x="223" y="113" height="156"
                        width="500"
                        labelField=""
                        ></mx:TileList>
                        </mx:Application>
                        • 9. Re: Array Collection
                          DM277 Level 2
                          Could you please check whether you are passing the corect parameter "business" or "communication"?.CategoryList.SelectedItem will be returning an object not string.
