12 Replies Latest reply on May 27, 2009 8:02 AM by kglad
    Interesting Preloader Qestion...
    esco1313 Level 1
      Hey All!
      Anyone would have a clue on how to achieve this result using actionscript (not the percent animation, i pretty much figured it out..)? What i mean is the "shaky/blury" effect...
      An example of script would be apreciated, since i'm not an expert...
      Thanks!!
      http://flashden.net/item/nervous-preloader/43007
        • 1. Re: Interesting Preloader Qestion...
          you can do that using the blur filter and momentary changes in the _x or x property of your movieclip textfield.
          • 2. Re: Interesting Preloader Qestion...
            esco1313 Level 1
            ok and i that achievable by actionscript? or do i have to key frames?
            • 3. Re: Interesting Preloader Qestion...
              esco1313 Level 1
              ok so i'm doing a test... so far, i have a sqare called "carre". on the 1st frame, my code:
              import flash.filters.BlurFilter;
              import mx.transitions.Tween;
              import mx.transitions.easing.*;
              var myTween:Tween = new Tween(carre, "blur", Strong.easeInOut, 0, 20, 1/5, true);
              myTween.onMotionChanged = function() {
                      carre._parent.filters = [new BlurFilter(carre.blur, carre.blur, 1)];
              i want to add a randomness on the blur and position..?
              EDIT
              ok i've added this code ON my movieCLip. But i dont want it to be on the mc...
              onClipEvent (load) {
              cx = this._x;
              cy = this._y;
              onClipEvent (enterFrame) {
              this._x = cx+(1+Math.random()*5);
              this._y = cy+(1+Math.random()*5);
              PLUS, it shakes randomly, but with no pause... like i would like it to...
              what should i do?
              • 4. Re: Interesting Preloader Qestion...
                esco1313 Level 1
                anyone? ...:(
                • 5. Re: Interesting Preloader Qestion...
                  SvingXD
                  To make it stop all you have to do is add a timer code, something like this onto the script:
                  startTime = getTimer();
                  this.onEnterFrame = function () {
                  currentTime = getTimer();
                  if(currentTime-startTime > 1000) {
                  You can change the '1000' value to experiment with different lengths of time, hope that helps.
                  • 6. Re: Interesting Preloader Qestion...
                    don't attach code to objects.  you can then use:
                    cx = carre._x;
                    cy = carre._y;
                    carre.onEnterFrame = function() {
                    // then when you want to stop the shaking use:
                    carre.onEnterFrame = null;
                    • 7. Re: Interesting Preloader Qestion...
                      esco1313 Level 1
                      thanks! it works. However, what i meant by stopping the shake was stopping it momentarily. Like in the example. its a random shake in time too...
                      any ideas?
                      • 8. Re: Interesting Preloader Qestion...
                        when you want the shaking to start call:  startShakeF()
                        when you want the shaking to stop call: stopShakeF()
                        cx = carre._x;
                        cy = carre._y;
                        function startShakeF(){
                        carre.onEnterFrame = shakeF;
                        function shakeF() {      this._x = cx+(1+Math.random()*5);      this._y = cy+(1+Math.random()*5); }; // then when you want to stop the shaking use: function stopShakeF(){
                        • 9. Re: Interesting Preloader Qestion...
                          esco1313 Level 1
                          ok i think that my description ist clear. What i'm trying to achieve in actionscript: if i had a movieclip, and i animated it so that it would shake for lets say...10 frames, then stop shaking for 20 frames, then shake for hmm..15 frames? then stop for 30 frames... i mean randomly. so whenever it would shake, it would blur (to create motionblur effect) but would shake randomly in time...
                          i want to achieve that with a script. is it possible?
                          • 10. Re: Interesting Preloader Qestion...
                            yes.  you can use timers to call those two functions when you want.  for example:
                            var startTimer:Timer=new Timer(5000,0);
                            var stopTimer:Timer=new Timer(2500,1);
                            startTimer.addEventListener(TimerEvent.TIMER,startShakeF);
                            startTimer.start();
                            stopTimer.addEventListener(TimerEvent.TIMER.stopShakeF);
                            function startShakeF(e:Event){
                            stopTimer.reset();
                            stopTimer.start();
                            //rest of code
                            • 11. Re: Interesting Preloader Qestion...
                              esco1313 Level 1
                              AAAAAHHhhhhhhhhhhhhhhh...... i get it.. i'll try that!
                              thanks, ill give you news
