4 Replies Latest reply on May 26, 2009 12:31 PM by ice9_us
    working with ArrayCollection
    ice9_us
      It is the simple stuff that gets us..
      if ( event.result.server_stats[a].@stat_name == "SwapCached" ) {
      //myServStatMeminfo.addItem({MeminfoMemFree:event.result.server_stats[a].@value/1024,Memin foDate:server_stat_xml[a].@stats_date});
      myServStatMeminfo.addItem({MeminfoSwapCached:event.result.server_stats[a].@value/1024});
      I am adding data to an array collection this way..
      i want to test to see
      A.. if this item is in the arraycollection
      B.. what is its value..
      I have tried a few ways:
      for (var
      z:Number=0; z < myServStatMeminfo.length; z++ ) {
      trace(myServStatMeminfo[z].hasOwnProperty("MeminfoSwapCached") );
      //trace( myServStatMeminfo.getItemIndex( MeminfoSwapTotal ) );
      How do i test this property and acces the value..
      Thanks in advanced for any help.
        • 1. Re: working with ArrayCollection
          ice9_us Level 1
          nevermind.. i am a nut.. I got it..
          • 2. Re: working with ArrayCollection
            Gregory Lafrance Level 6
            Please share the solution.
            • 3. Re: working with ArrayCollection
              ice9_us Level 1
              i really don't like this text interface.. i like the old stuff much better...
              It really came down to a  HARDWARE issue... loose nut behind the keyboard..
              my understanding was correct.. I was not running through my data correctly  i had a type-O when calling hasOwnProperty..
              for (var z:Number=0; z < myServStatMeminfo.length; z++ ) {
              if ( myServStatMeminfo[z].hasOwnProperty("MeminfoVmallocUsed") == true && vmalloc_ChartOn != 1 ) {
              trace("vmalloc has own prop " + myServStatMeminfo[z].hasOwnProperty("MeminfoVmallocUsed") );
              vmalloc_ChartOn=1;
              if ( myServStatMeminfo[z].hasOwnProperty("MeminfoSwapTotal") == true && swap_ChartOn != 1 ) {
              trace("has own swap prop " + myServStatMeminfo[z].hasOwnProperty("MeminfoSwapTotal") );
              • 4. Re: working with ArrayCollection
                ice9_us Level 1
                vmalloc_ChartOn=1;
