11 Replies Latest reply on May 27, 2009 7:58 AM by kglad
    Loading php output into flash to determine message
    mikeyjray
      Hi there,
      I am using the following tutorial to create a php message page, however, even in their example, I cannot get the php echo function to send the output to the dynamic text fields: http://www.sephiroth.it/tutorials/flashPHP/email/index.php.
      Here is the button code to send the php variables and attempt to capture the php echo of either "sent" or "error"
      on (release) {
          //    Now import the variables we
          //    need to send in this movie clip
          sender_mail = _root.Semail.text
          sender_name = _root.Sname.text
          sender_subject = _root.Ssubject.text
          sender_message = _root.Smessage.text
          //    all the vars we just imported
          //    will be sent via POST method now
          loadVariables("sendmail.php",this,"POST");
          //    and when receives the answer from
          //    the server...
          this.onData = function()
              //    ok, next frame
              _root.nextFrame();
              if(this.output=='sent')
                  // in case of success
                  _root.errTitle = 'Thank You.';
                  _root.errType = "Your message has been succesfully sent.";
              } else {
                  //    else
                  _root.errTitle = "Error!";
                  _root.errType = "Attention, an error occurred. Please try again later.";
      Here is the php which should echo the "sent" or "error"
      if(!empty($HTTP_POST_VARS['sender_mail']) || !empty($HTTP_POST_VARS['sender_message']) || !empty($HTTP_POST_VARS['sender_subject']) || !empty($HTTP_POST_VARS['sender_name']))
           $to = "email@website.com";
           $subject = stripslashes($HTTP_POST_VARS['sender_subject']);
           $body = stripslashes($HTTP_POST_VARS['sender_message']);
           $body .= "\n\n---------------------------\n";
           $body .= "Mail sent by: " . $HTTP_POST_VARS['sender_name'] . " <" . $HTTP_POST_VARS['sender_mail']  . ">\n";
           $header = "From: " . $HTTP_POST_VARS['sender_name'] . " <" . $HTTP_POST_VARS['sender_mail'] . ">\n";
           $header .= "Reply-To: " . $HTTP_POST_VARS['sender_name'] . " <" . $HTTP_POST_VARS['sender_mail'] . ">\n";
           $header .= "X-Mailer: PHP/" . phpversion() . "\n";
           $header .= "X-Priority: 1";
           if(@mail($to, $subject, $body, $header))
                echo "output=sent";
           } else {
                echo "output=error";
      } else {
      The email does send fine, but it does not show the message which lets the user know the status of the message.  Any ideas?  There is a link to download the .zip file of the tutorial - I have attached it here.
