0 Replies Latest reply on Sep 22, 2008 2:04 PM by walker6o9
    Saving Files to User Hard Drive
    walker6o9
      I'm using Adobe AIR to save files to the user's hard drive. The problem I'm having is that if the file is contained in folder and I try to save it to the User's harddrive, it creates that folder in the user's harddrive and saves the file in that folder. I've attached the code below, at least the parts of my code that I think are relevant. I can include the whole thing if need be.
      public function showDownloadScreen()
      this.downloadscreens.enabled = true;
      this.downloadscreens.visible = true;
      this.downloadscreens.alpha = 100;
      this.downloadscreens.gotoAndStop("start");
      var files:String;
      var index:Number;
      var filename:String;
      var filepath:String;
      filepath = fileList[0];
      index = filepath.lastIndexOf("/");
      filename = filepath.substring( index + 1, filepath.length );
      files = filename;
      for (var i:Number = 1; i < fileList.length; i++)
      filepath = fileList ;
      files = files + ", " + filename;
      this.downloadscreens.start.bodytext.text = "To save the selected file(s):\n" + files
      + "\n\nto your computer, please click the download button and select a destination.";
      public function showCompleteScreen():void
      this.downloadscreens.gotoAndStop("complete");
      var index:Number;
      index = file.nativePath.lastIndexOf("/");
      filepath = file.nativePath.substring( index + 1, file.nativePath.length );
      this.downloadscreens.complete.bodytext.text = "Your file(s) have been saved to " + filepath + ".";
      public function showErrorScreen():void
      this.downloadscreens.complete.bodytext.text = "Error! File not found.";
      public function hideDownloadscreens(evt:Event):void
      this.downloadscreens.alpha = 0;
      this.downloadscreens.enabled = false;
      this.downloadscreens.visible = false;
      public function startDownload( evt:Event )
      this.hideDownloadscreens(evt);
      file.addEventListener( Event.SELECT, dirSelected );
      file.browseForDirectory( "Select a directory" );
      // Open a directory selection window
      public function dirSelected( evt:Event )
      if ( this.fileList.length > 0 )
      this.currentFile = 0;
      this.loadFile();
      public function loadFile():void
      var filename:String = this.fileList[this.currentFile];
      var byteLoader:URLLoader = new URLLoader();
      byteLoader.dataFormat = URLLoaderDataFormat.BINARY;
      byteLoader.addEventListener( Event.COMPLETE, onDownloaded );
      byteLoader.addEventListener( SecurityErrorEvent.SECURITY_ERROR, securityErrorHandler );
      byteLoader.addEventListener( HTTPStatusEvent.HTTP_STATUS, httpStatusHandler );
      byteLoader.addEventListener( IOErrorEvent.IO_ERROR, ioErrorHandler );
      var fileRequest = new URLRequest( filename );
      try
      byteLoader.load( fileRequest );
      catch (error:Error)
      this.showErrorScreen();
      public function securityErrorHandler(event:SecurityErrorEvent):void
      this.downloadscreens.complete.bodytext.text = "Error! The security settings prevent you from saving\nthese files to your computer.";
      public function httpStatusHandler(event:HTTPStatusEvent):void
      this.downloadscreens.complete.bodytext.text = "Error! HTTP error, file wasn't found.";
      public function ioErrorHandler(event:IOErrorEvent):void
      this.downloadscreens.complete.bodytext.text = "Error! IO error, file wasn't found.";
      // On file downloaded, save file
      public function onDownloaded(evt:Event)
      saveFile( file.nativePath + "/" + filename, evt );
      this.currentFile++;
      if ( this.currentFile < this.fileList.length )
      loadFile();
      else
      showCompleteScreen();
      // Write file to hard drive
      public function saveFile( filename:String, evt:Event )
      var myFile:File = File.documentsDirectory.resolvePath( filename );
      var myFileStream:FileStream = new FileStream();
      myFileStream.open( myFile, FileMode.WRITE );
      myFileStream.writeBytes( evt.target.data, 0, evt.target.data );
