1 Reply Latest reply on May 26, 2009 1:21 PM by Brent Lamborn
    Need to load WSDL from external file
    Jaishah11
      Hello,
      I have to override the SOAP address location generated by a webservice and call the webservice from the correct location.
      Is there any way I can load WSDL in flex using an external file or override the SOAP address location.
      Please reply soon.
      Best Regards,
      Jai
        • 1. Re: Need to load WSDL from external file
          Brent Lamborn Level 2
          If you used the "Data > Import Web Service (WSDL)" feature in Flex Builder to import the WSDL into your Flex application, then the generated service class should have a parameter named "rootUrl" in the constructor. At runtime you can determine what url you need and pass it into the contructor with the rootUrl parameter.
