5 Replies Latest reply on Nov 4, 2009 10:02 AM by TaylorBastien
    crossdomain.xml issue
    aprildavid
      I am facing a problem. I am working on socket. If I run my application from eclipse's flex plugin, it works fine.
      But I load the swf to server, I got "on ErrorError #2048: Security sandbox violation: https://10.3.54.30:4343/HttpStreaming.swf cannot load data from 10.3.54.30:4343.".
      I have put the crossdomain.xml under directory to allow any access and any port.We can't open another port 843 as recommonded by adobe. So I directly called Security.loadPolicyFile("http://10.3.54.30/images/crossdomain.xml");
      MY code is below. Can you tell me how to fix the problem? A lot of thanks!
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" xmlns:cmp="org.httpclient.*" borderStyle="none" height="500" width="500" creationComplete="initInterface()">
      <mx:Script>
      <![CDATA[
          import com.adobe.net.URI;
          import org.httpclient.events.*;
          import mx.controls.TextArea;
          import mx.containers.Panel;
           import mx.controls.Alert;
          import asscript.*;
          import org.httpclient.*;
          var output:TextArea;
          var bufferSize:int=1024;
          var dataIn:Array=new Array();
          var rDataSize:int=0;
          var count:int=0;
          var inputByteArray:ByteArray=new ByteArray();
          var dataString:String=new String();
          var s1:Number;
          var s2:Number;
           public function initInterface():void
               output=new TextArea();
               output.width=500;
               output.height=500;
              this.addChild(output);
              /* var myTimer:Timer = new Timer(100, 20000);
              myTimer.addEventListener("timer", updateUI);
              myTimer.start(); */
              var client:HttpClient = new HttpClient();
          /*    client.listener.onStatus = function(event:HTTPStatusEvent):void
                   Alert.show("on status");
          client.listener.onData = function(event:HttpDataEvent):void
                var d:ByteArray = event.bytes;
                inputByteArray.writeBytes(d);
                count=count+d.length;
            //    if(inputByteArray.length>=bufferSize)
                    updateUI1();
                /*var d:String= event.readUTFBytes();
                rDataSize=rDataSize+d.length;
                if(rDataSize>bufferSize)
                    rDataSize=0;
                    updateUI1();
          client.listener.onComplete = function(event:HttpResponseEvent):void {
              var now2:Date=new Date();
              s2=now2.getTime()-s1;
               Alert.show("on Complete"+count +"time "+s2+ "array="+inputByteArray.length);
               updateUI2();
          client.listener.onError = function(event:ErrorEvent):void {
            var errorMessage:String = event.text;
            Alert.show("on Error"+errorMessage);
          var uri:URI = new URI("http://10.3.54.30/images/spectrumdata");
          var now:Date = new Date();
          s1=now.getTime();
          client.get(uri);
          public function updateUI(event:TimerEvent):void
              output.text+=".";
          public function updateUI2():void
          /*    var iByteArray:ByteArray=new ByteArray();
              iByteArray.writeDouble(Math.PI);
              iByteArray.position=0;
              var k:Number=iByteArray.readDouble();
               output.text+=" "+k;*/
              inputByteArray.position=0;
             do
              var i:uint=inputByteArray.readByte();
              output.text+=i+" ";
            while(inputByteArray.bytesAvailable!=0);
          public function updateUI1():void
              // var bArray:ByteArray=new ByteArray();
              /*if(inputByteArray.length>1024)
                  inputByteArray.readBytes(bArray,0,1024);*/
              output.text+=".";
      </mx:Script>
      </mx:Application>
