I have been experiencing some issues playing back clips inside Premiere Pro CS3.
The clips are of analog footage captured from inside Premiere Pro CS3 using a firewire converter.
When viewing the timeline in the program monitor and when the output is Composite Video, I get an immediate response when I hit the space bar to play and pause the clips. However, when I select the YC Waveform and then press the spacebar to playback the timeline, then press the space bar again, there is about a 5 to 10 second delay before the clip stops. In that 5-10 second time period, Premiere Pro is renderred usless.
The situation is the same even if I play the clips back from a higher speed (200MB/s+) Raid array.
The clips do not have any filters or effects on them.
I'm using the NTSC standard 48khz project settings.
Is this normal?
I am running a quad core q6600 CPU.
Thanks in advance
Kelvin
