6 Replies Latest reply on May 27, 2009 3:16 AM by skrv
    XMLListCollection and Charts
    skrv Level 1
      Hi there is a XML list collection XML node is of following format -
      <abc>
           <id></id>
           <room_id></room_id>
           <center_id></center_id>
           <name></name>
           <city></city>
           <date></date>
      </abc>
      relationship - one center has many rooms
      i need to chart -
      x axis -> month and
      y axis -> total number of rooms belonging to that center
      legend is different different centers
      I tried the linechart with dataprovider as XLC, how to do runtime selection and calculation on XMLListCollection
      should i include more details
      Regards,
      Sawan
        • 1. Re: XMLListCollection and Charts
          _Natasha_ Level 4
          may be it's posible.
          What is the format for date element?
          • 2. Re: XMLListCollection and Charts
            skrv Level 1
            date is SQL date element that has date and time
            but the date.month gives out the number and that doesnot map collectively into x axis that is --
            say i have following entries -
            date           name          center_id          room_id
            8/9/09        abc1              1                      1
            8/9/09        abc2              1                      1
            8/9/09        abc3              3                      2
            8/9/09        abc4              3                      1
            8/9/09        abc5              2                      2
            8/10/09        abc6            2                      1
            8/10/09        abc7            1                      1
            8/9/09        abc8              1                      2
            8/9/09        abc9              2                      1
            8/9/09        abc10            2                      1
            8/10/09        abc11          3                      2
            8/9/09        abc12            3                      1
            8/10/09        abc13          3                      1
            so there are two months sep/oct so these should be there are x axis vs number of rooms on y axis w.r.t center
            sep center 1  number of rooms 3
            sep center 2   number of rooms 2
            sep center 3  number of rooms 2
            oct center 1  number of rooms 1
            oct center 2   number of rooms 1
            oct center 3  number of rooms 2
            graph is as follows
            How can i go about this?
            Regards,
            Sawan
            • 3. Re: XMLListCollection and Charts
              _Natasha_ Level 4
              No, you should prepare data for chart.
              Very difficult:
              select data for only one center (series per center)
              extract month from date
              show count of nodes per month
              • 4. Re: XMLListCollection and Charts
                skrv Level 1
                Yes, issues i am facing is to manipulate XMLListCollection and play with it.
                there are not many examples to manipulate the XMLListCollection [XLC] to do all these the steps as you said are -
                store the XLC in some temp table
                replace all the date fields with there month
                replace all rooms belonging to a single center with center ID [information about which room is lost - we need total number]
                now while showing into the chart how to say that if the month name is same put them in same column
                how can i go about this?
                Regards,
                Sawan
                • 5. Re: XMLListCollection and Charts
                  _Natasha_ Level 4
                  You should create new XLC for dataProvider to chart with data like. And it will be better to save XML from original data.
                  <center id="1">
                  <item month="september" count="3"/>
                  <item month="oct" count="3"/>
                  </center> (for each center)
                  So first you extract month.
                  for each (var d:XML in oldXML.abc.data)
                       // parse month and save only month in d
                       // also save all existing unique months
                  Also you need a list if center ids. If you have it - good. If no
                  for each (var c:XML in oldXML.abc.center_id)
                  // save unique items to list
                  After loop in centers list and months
                  for each (var items:XMLList in oldXML.abc.(center_id == current_center_id))
                  // data for one center
                       for each (var inOneMonth:XMLList in items.(date == current_month))
                       // add item with month and lenth of XMLList to newDataProvider
                  • 6. Re: XMLListCollection and Charts
                    skrv Level 1
                    Hmm yes, after reading through above solution and some others i figured that its difficult to work with syntax of XMLListCollection so I converted it to ArrayCollection using IViewCursor and then parsing those tables to create individual chart tables. But now i have to create table for each chart still good as i can export those tables to excel sheet as added feature
                    Thanks for your help Natasha.
