5 Replies Latest reply on Jun 8, 2009 5:59 PM by fazstp
    ...connect to a shared folder on a MAC with director 11???
    DigitalDesignMedia Level 1
      Hi All,
      I developed a project a few years ago that work as follows.
      This was designed to work on Win XP, using Director MX2004
      Server Setup
      All the media files where installed on a server and the folder they resided in was setup as a shared folder.
      Workstation Setup
      A projector was installed on a workstation PC, along with the director projector, a txt file was install, the txt file contained the unc path to where all the media files resided. i.e. all director & video file etc.
      The projector file would read the text file, get the unc path, and open the appropriate dxr file.
      This worked really well.
      ___________________
      My question is, now I'm upgrading the software to Director 11, it is required to work the same way on MAC OSX. The only difference to the system will be that the media files will reside on a MAC server and the workstations will be MACs (Intel MACs running the latest OSX).
      How can you connect to a shared folder on a MAC with director 11?
      Its not '\\share_name'... should 'afp:\\share_name' work???
      I keep getting the can't find 'myfile.dxr' alertbox
      I hope I've explained myself well enough.
      Any help would be very much appreciated.
      Jason
        • 1. Re: ...connect to a shared folder on a MAC with director 11???
          fazstp Level 2
          I don't know about doing it from Director 11 but you can do it with applescript.
          In the AppleScript ScriptEditor paste the following code then save it as an application (like "Mount.app") in the same folder as the projector.
          Next in Director you would write the volume path and password
          ie. afp://username:password@volumepath/sharename
          into a text file (like "Mount.txt")
          Then use open command from Director to mount the volume
          open _movie.path & "Mount.txt" with _movie.path & "Mount.app"
          -- applescript below
          on open (theFile)
            set theVolume to readFile(theFile as text)
            if (theVolume is "") then
              return false
            end if
            try
              mount volume theVolume
              return true
            on error
              return false
            end try
          end open
          on readFile(theFileName)
            try
              set theFileRef to (open for access file theFileName)
            on error
              return ""
            end try
            try
              set theText to (read theFileRef)
            on error
              set theText to ""
            end try
            close access theFileRef
            return theText
          end readFile
          • 2. Re: ...connect to a shared folder on a MAC with director 11???
            Hi Fazstp,
            Just wanted to say big thank-you , this worked a treat.
            Kind Regards,
            Jason
            • 3. Re: ...connect to a shared folder on a MAC with director 11???
              fazstp Level 2
              Glad I could help.
              I've barely scratched the surface when it comes to AppleScript but it can certainly be a valuable extension to interact with other applications.
              -Stephen
              • 4. Re: ...connect to a shared folder on a MAC with director 11???
                Hi Stephen,
                Do you know to remove the mounted drive using apple script? I just want to tidy up after the app closes.
                Jason
                • 5. Re: ...connect to a shared folder on a MAC with director 11???
                  fazstp Level 2
                  Using a similar technique you could write the name of the mounted volume (just the name in this case, not the full path) to a text file and open it with a separate AppleScript app containing the applescript below. Note that any files you have accessed from the volume will probably have to be unlinked before Finder will be able to eject it.
                  on open (theFile)
                      return false
                    end if
                    try
                      tell application "Finder"
                        eject theVolume
                      end tell
                      return true
                    on error
                      return false
                    end try
                  end open
                    try
                    on error
                      return ""
                    end try
                    try
                    on error
                      set theText to ""
                    end try
                    return theText
                  end readFile
