3 Replies Latest reply on May 27, 2009 7:26 AM by Set Screen name
    How to defeat the shadow?
    Set Screen name
      I have an ObjectStyle, that has shadow in its properties. Now i need to switch off this option.
      I tried like this:
      myDoc.AllObjectStyles.Item("my").ContentEffectsEnablingSettings.EnableDropShadow = False
      myDoc.AllObjectStyles.Item("my").FillEffectsEnablingSettings.EnableDropShadow = False
      myDoc.AllObjectStyles.Item("my").ObjectEffectsEnablingSettings.EnableDropShadow = False
      myDoc.AllObjectStyles.Item("my").StrokeEffectsEnablingSettings.EnableDropShadow = False
      It didn't help.
      Then tried this (to directly kill some shadow settings):
      myDoc.AllObjectStyles.Item("my").ContentTransparencySettings.DropShadowSettings.XOffset = 0
      myDoc.AllObjectStyles.Item("my").ContentTransparencySettings.DropShadowSettings.YOffset = 0
      myDoc.AllObjectStyles.Item("my").ContentTransparencySettings.DropShadowSettings.Size = 0
      myDoc.AllObjectStyles.Item("my").ContentTransparencySettings.DropShadowSettings.Opacity = 0
      Also no effect. But in Objstyle properties the "check mark" appeared in grey color (means, as far as i guess, "partly activated").
      So, how to switch on/off this ... shadow?
        • 1. Re: How to defeat the shadow?
          Harbs. Level 6
          Try this:
          myStyle.transparencySettings.dropShadowSettings.mode = ShadowMode.NONE
          • 2. Re: How to defeat the shadow?
            Set Screen name Level 1
            This worked only on selected object and in this syntaxis:
            mInd.Selection.Item(1).TransparencySettings.DropShadowSettings.Mode = 1852796517 'shadow off
            mInd.Selection.Item(1).TransparencySettings.DropShadowSettings.Mode = 2020623440 'shadow on
            But in ObjStyles doesn't work. Moreover, after manual removing  shadow from object, which has objSt with shadow, this option "almoust" disappear from style properties.  This is smth....
            • 3. Re: How to defeat the shadow?
              Worked after this:
              myDoc.ObjectStyles.Item(i).ContentEffectsEnablingSettings.EnableDropShadow = True
              myDoc.ObjectStyles.Item(i).FillEffectsEnablingSettings.EnableDropShadow = True
              myDoc.ObjectStyles.Item(i).ObjectEffectsEnablingSettings.EnableDropShadow = True
              myDoc.ObjectStyles.Item(i).TransparencySettings.DropShadowSettings.Mode = 1852796517 'removing shadow from style options. ... Huh...
              Thanks for help.
