2 Replies Latest reply on May 27, 2009 3:57 AM by lewisdarby.com
    Adding diffusion/light wrap
    lewisdarby.com
      Hi all,
              I'm working on a project that has an animated character set in a background. There is very strong lighting coming through the doorway behind the character (the character is silhouetted) and I want to add a subtle light wrap around the character so it looks like the light is just creeping round the edges.
      Any ideas how i might do this?
      thanks,
      - lewis
        • 1. Re: Adding diffusion/light wrap
          Assuming your character is separate from your character:
          a) Duplicate the layer 2 times, I will call this Layer A (on top) and Layer B (below)
          b) Layer B: Effect --> Channel --> Invert, set to Alpha
          c) Layer B: Effect --> Channel --> Minimax or Effect --> Matte --> Simple Choker to expand
          d) Layer B: Effect --> Generate --> Fill
          e) Layer B: Effect --> Blur and sharpen --> Box Blur
          f) Use Layer A as a matte on Layer B
          g) Set Layer A to Add blending mode
          If you want to use complex background colors, another level of matting and nesting is required, where the result of the foreground would act as a matte on the background, then blurred. If you have CS3 or CS4, Photoshop Layer Styles (Inner Glow) are also available. of course any variation on the them is possible by throwing more effects into the pot or using different methods...
          Mylenium
          • 2. Re: Adding diffusion/light wrap
            lewisdarby.com Level 1
            brilliant! thanks very much. Much appreciated
            - lewis
