1 Reply Latest reply on May 29, 2009 8:06 AM by Mr Bounce
    [AS] Copy/Paste graphics
    Mr Bounce
      Just wondering if anyone can help... l'm trying to copy/paste graphics from one document to another.
      I've been doing this my getting the file path of item link of graphic 1 and then setting this value to the frame on the other document - then setting the offset etc to move it to the correct place - which works great. (see below code)
      The problem l've got it sometimes the original graphic file doesn't exists so it does not work - what l want to do is then copy the 'preview' image you see on the document and paste that in the box on the other document - just like a normal copy/paste
      Any ideas on a nice way of doing this?
      This is my current copy/paste methods l talked about:
      on copyItem(boxName)
           try
           tell application "Adobe InDesign CS3"
                set myCopyDocument to active document
                set proceed to false
                tell myCopyDocument
                     set theSelection to graphic 1 of page item boxName
                     set theTarget to parent of theSelection
                     set FilePathOfImage to file path of item link of graphic 1 of theTarget
                     set {a, b, c, d} to geometric bounds of theSelection
                     set {w, x, y, z} to geometric bounds of theTarget
                     set xOff to a - w
                     set yOff to b - x
                end tell
                return {true, FilePathOfImage, xOff, yOff}
           end tell
           on error msg
                display dialog "Can not copy original image: " & msg
                return {false, "", 0, 0}
           end try
      end copyItem
      on pasteItem(boxName, FilePathOfImage, xOff, yOff)
            try
                tell myPasteDocument
                     set myImage to place FilePathOfImage on page item boxName
                     set {a, b, c, d} to geometric bounds of myImage
                     set geometric bounds of myImage to {a + xOff, b + yOff, c + xOff, d + yOff}
                end tell
           on error msg
                display dialog "Can not place original image: " & msg
           end try
           end tell
      end pasteItem
      Regards, Gary.
        • 1. Re: [AS] Copy/Paste graphics
          Mr Bounce Level 1
          Worked out a way of doing it with the following:
          property myDocuments : {}
          set boxName to "pic1"
              -- Source
              set MyRectangles to page item boxName of document 1
              set MyRectangle to item 1 of MyRectangles
              set thePage to parent of MyRectangle
              set thePageNumber to name of thePage
              -- Target
              set MyTargetRectangles to page item boxName of document 2
              set MyTargetRectangle to item 1 of MyTargetRectangles
              set theTargetPage to parent of MyTargetRectangle
              set theTargetPageNumber to name of theTargetPage
              set {y, x, l, h} to geometric bounds of MyTargetRectangle
              -- Duplicate onto document 2
              set MyTargetRectangleCopy to duplicate MyRectangle to page theTargetPageNumber of document 2
              -- Delete old target
              delete MyTargetRectangle
              -- Move new target to old targets place
              move MyTargetRectangleCopy to {x, y}
          end tell
