1. Re: Make it so "Step Backward" does NOT change layers
harry teasley May 27, 2009 8:03 PM (in response to tshill)Or non-history enabled actions could be appended to the preceding history entry instead of being prepended to the following history entry.
It has been asked for a lot.
2. Re: Make it so "Step Backward" does NOT change layers
Reynolds (Mark) May 29, 2009 8:39 AM (in response to harry teasley)Yes I support this one. Default behaviour should remain as it is, but there should be an option or a preference, meaning that Command Option Z doesnt flip layers if you don't want.
3. Re: Make it so "Step Backward" does NOT change layers
fruityth1ng-T0qBnM Jun 4, 2009 7:25 AM (in response to tshill)I work in a gaming studio, and amongst the artists this is our number one problem with photoshop.
It's an especially big Gripe for me, since I'm the GUI guy, and work with a LOT of layers.
I recall asking for this myself a while back on these same forums, by the way - so Adobe, if you're reading this: PLEASE prioritize this. Thank you!
4. Re: Make it so "Step Backward" does NOT change layers
olias32 Jan 11, 2011 3:15 PM (in response to tshill)Seems a lot of people have this problem, and someone wrote a script to fix it.
See here: http://www.polycount.com/forum/showthread.php?p=1251347#post1251347
Also, note you need to copy the script in the Photoshop/Presets/Scripts folder for it to show in the Scripts menu. Once it's there, you can assign any keyboard shortcut to it - CTRL+Z of course
Photoschop CS3 and up i think.
5. Re: Make it so "Step Backward" does NOT change layers
i_only_know Jan 29, 2011 7:52 PM (in response to olias32)You don't need a script to fix what's not broken
READ THE HELP MANUAL!
6. Re: Make it so "Step Backward" does NOT change layers
Thanks, genius. That's why we're here. We went through the static documentation and found it wanting.
This history "feature" is seen by many as a "bug." Since it previously existed just fine in a different form, it's not inconceivable that Adobe could return it to its former state (or give us the option to do so).
