4 Replies Latest reply on May 28, 2009 3:41 PM by Quirky Quintus
    How can I export to 1920x1080 Progressive at 25fps - in MPEG2 (.m2v format) from After effects?
    Quirky Quintus
      Hello all,
      As the title suggests, I have been unable to export in the above-mentioned format.
      Through the Mainconcept export (using the "MPEG2 Blu-Ray" export settings), I can only get interlaced export settings, using 25fps. It is only through the NTSC settings that I can get Progressive frames - but not 25fps...
      Is there no way to override the settings manually? The final output is for hard-drive playback - not for Bluray encodings... Is there maybe a plugin that will do that?
      The full specs I need follow:
      1920x1080 pixels
      Pixel ratio 1
      25 fps
      Progressive output...
      .m2v file
      Quite simple, no? Any help is greatly appreciated. Many thanks in advance!
      PS> we are using both MACs(10.5) and PCs (XP) and After Effects CS4.
