8 Replies Latest reply on May 29, 2009 7:15 AM by kglad
    Html turns to percent signs
    kristinx1367
      I am trying to load html into a text box from a website. when i load to the text box, everything goes fine except that it is loaded as something that looks like this:
           "%20Cheese%20Croissant=&nbsp%3B%3Cimg%20src=%22http%3A%2F%2Fwww%2Ehousing%2Eumich%2Eedu%2Fd ining%2Fmenus%2Fm%2Dfit%2Egif%22%20alt%3D%22%2A%22%3E%3C%2Fdiv%3E%3Cdiv%20class%3D%22Desse rts%22%3EOat%20Bran..."
      I wouldnt mind if the html tags were there, because I can deal with those, but I don't know what to do with this. Here is my loader:
      var my_lv:LoadVars = new LoadVars();
                      my_lv.onLoad = function(success:Boolean)
                           var mL:String = String(my_lv);
                           mc.mealList.htmlText = reformat(mL);
                           trace(mL);
                           mc.mealList._height = mc.mealList.textHeight;
                           mc.mealList.setTextFormat(foodFeedFormat);
                           mealTween = new Tween(mc.mealList, "_y", None.easeOut, 300, (mc.mealList._height * -1), (0.05 * mc.mealList._height),true);
                           mealTween.looping = true;
                      my_lv.load(website);
        • 1. Re: Html turns to percent signs
          unescape that string and you'll recover your html encoded string.
          • 2. Re: Html turns to percent signs
            kristinx1367 Level 1
            do you mean by just making it look like this:
                                           mc.mealList.htmlText = my_lv;
            because i tried getting rid of the String and it didnt change anything
            • 3. Re: Html turns to percent signs
              like so:
              // although that's not likely to display correctly because of the limited html tags flash can parse
                                             mc.mealList.htmlText = unescape(my_lv);
              • 4. Re: Html turns to percent signs
                When I did that, I got a "type mismatch" error.
                • 5. Re: Html turns to percent signs
                  I also don't mind if some of the html tags show up, because i can go through and systematically remove them afterwards. I just have to get it to display as html first, and not all these symbols. it cuts the whole beginning off too until it hits the last "&" sign.
                  • 6. Re: Html turns to percent signs
                    kglad wrote:
                    like so:
                                                   mc.mealList.htmlText = unescape(String(my_lv));
                    • 7. Re: Html turns to percent signs
                      ok, i've done that, and it showed up in html format! however, it's only got part of it (like the style html and a couple words from the body) was this what you were talking about when you said it wouldn't parse correctly? i was probably wrong, but i just thought that it would include the body and all the html tags. is there anything i can do so that all of the body shows up?
                      • 8. Re: Html turns to percent signs
                        if you think more data is being sent than is being presented in your textfield find the code that causes the data truncation by using the trace() function and possibly the flash string methods.
                        this is a separate issue though.  this thread has been answered.
