7 Replies Latest reply on Jun 8, 2009 3:23 AM by robegv
    A simple newbie question - retrieving data to edit and return
    robegv
      Hi
      I hope someone can help me (bit new to flex as you will be able to tell!)
      i have a simple form which allows me to enter details about a client(person) and save this to the database via coldfusion cfc so far so good.
      Howver a want to retriev that record record back later on a make changes.  difficulty i am having is not the retrieval of therecord itself, as the record can be returned to a datgrid with no probs, but binding the arraycollection to the relevant fields.
      my code so far is as follows trhe field i am looking for here is retrieved as a "Surname" and i want it top popluate the textinput field...
      (and i thought my learning was going so well  !)
      [Bindable]
         public var getepisode:ArrayCollection= new ArrayCollection ();
      //this is the bit that needs help methinks
      public function returnHandler(event:ResultEvent):void {
          Surname.text as Surname.string
            public function errorHandler(event:FaultEvent):void {
          Alert.show(event.fault.message);
          </mx:Script>
      <!-- insert rpc to get client data-->
      <mx:RemoteObject id="ClientQuery"
         destination="ColdFusion"
         source="buildtest.getepisode"
         showBusyCursor="true"
         fault="errorHandler(event)">
                <mx:method name="getepisode" result="returnHandler(event)"/>
      </mx:RemoteObject>
      <mx:Form>
        <mx:FormItem direction="horizontal" label="surname (roberts)" required="true" visible="true" width="100%" horizontalAlign="left">
           <mx:TextInput enabled="true" id="Surname" text="{returnHandler.Surname}"  width="100%" visible="true"/>
        </mx:FormItem>
      </mx:Form>
      grateful for any pointers
      cheers
        • 1. Re: A simple newbie question - retrieving data to edit and return
          Michael Borbor Level 4
          Hi there, if your function returns only one set of data if should be
          something like this
              Surname.text =event.result.Surname;
          • 2. Re: A simple newbie question - retrieving data to edit and return
            robegv Level 1
            Hi Michael
            thanks for your reply unfortunatley I am still not getting the field populated with the surname only a coded function (of "getclient42.Form44.FormItem57.Surname" )
            my code now looks like:
            [Bindable]
               public var getepisode:ArrayCollection = new ArrayCollection ();
                  Surname.text = event.result.Surname;
                </mx:Script>
            </mx:RemoteObject>
            <mx:Form>
                <mx:FormItem direction="horizontal" label="Surname" required="true" visible="true" width="100%" horizontalAlign="left">
                           <mx:TextInput enabled="true" id="Surname" text="{Surname}" width="100%" visible="true"/>
              </mx:FormItem>
            </mx:Form>
            still if i drop a datagrid in and set my dataprovider to be the getepisode array the grid returns my required data .
            I think i am getting closer, but not sure if i am setting the binding correct in the textinput field i thought i could just use the id and the value would be set and leave out the 'text=' statement.
            if i can crack this i think i get going for quiet a while before hittiing the next stumbling block  - any help as always much appreciated.
            cheers
            • 3. Re: A simple newbie question - retrieving data to edit and return
              Change your result handler to this
                 Alert.show(event.result.toString());
              and post here what you see in the the Alert window that will pop up when the data returns
              • 4. Re: A simple newbie question - retrieving data to edit and return
                robegv Level 1
                hi
                unfortunately there is nothing that gets returned in the alert it is just blank which is odd??
                i guess that means nothing is being returned, but thats true how come i can put in a datagrid control with the same query and get results???
                • 5. Re: A simple newbie question - retrieving data to edit and return
                  You mentioned a DataGrid but in your code I can't see a DataGrid. Could you post that bit of code as well?
                  • 6. Re: A simple newbie question - retrieving data to edit and return
                    robegv Level 1
                    Hi
                    Thanks fro your reply.
                    With regard to the datagrid, I was using that to check that something was being returned in the ArrrayCollection. The code below show the array in the datagrid fine , no probs, i have left in ,but commented out, the alert part.
                    The "clientref" field is passed into the code from a calling window and the grid shows the expected results, it just doesn't seem toget to the textinput field, v. odd..
                    Thanks for any help - i am losing hair rapidly
                    Full code.......
                    <mx:TitleWindow xmlns:mx="http://www.adobe.com/2006/mxml" creationComplete="initApp()" creationPolicy="all"
                    showCloseButton="true" xmlns:ns1="*" width="902" height="516"
                    close="PopUpManager.removePopUp(this);" horizontalAlign="left" title="get client record">
                      <mx:Script>
                            <![CDATA[
                                import mx.managers.PopUpManager;
                                import mx.controls.TextArea;
                                import mx.controls.Text;
                                import mx.printing.*;
                               import mx.events.ValidationResultEvent;
                                import mx.rpc.Fault;
                                import mx.rpc.events.FaultEvent;
                                 import mx.rpc.events.ResultEvent;
                                import mx.collections.ArrayCollection;
                                import mx.controls.Alert;
                                import mx.controls.CheckBox;
                                import mx.controls.TextInput;
                                import mx.events.*;
                                import mx.collections.*;
                                import mx.controls.DataGrid;
                                public function initApp():void {
                        ClientQuery.getepisode();
                        // This function is called from main screen to put data into a text field
                       public function passData(passedData:String):void {
                        ClientRef.text = passedData
                                    private function handleCreationComplete():void {
                                    // Center the TitleWindow container over the control that created it.
                                    PopUpManager.centerPopUp(this);
                                   this.setStyle("borderAlpha", 1);
                      [Bindable]
                         clientDatagrid.dataProvider = event.result;
                         // Alert.show(event.result.tostring());
                        </mx:Script>
                    </mx:RemoteObject>
                    <mx:Form>
                       <mx:FormItem direction="horizontal" label="ClientRef" required="true"  visible="true" width="100%" horizontalAlign="left">
                              <mx:TextInput text="clientref" id="ClientRef" editable="false" visible="true" width="100%"/>
                       </mx:FormItem>
                         <mx:TextInput enabled="true" id="Surname"  width="100%" visible="true"/>
                      </mx:FormItem>
                      <mx:FormItem direction="horizontal" label="Forename" required="true" visible="true" width="100%" horizontalAlign="left">
                         <mx:TextInput enabled="true" id="Forename" text="" width="100%" visible="true"/>
                      </mx:FormItem>
                    </mx:Form>
                    <mx:DataGrid id="clientDatagrid"/>
                    </mx:TitleWindow>
                    • 7. Re: A simple newbie question - retrieving data to edit and return
                      robegv Level 1
                      Hi Michael,
                      Any chance you can have a look at the code i posted last week - this should be a minute fix but I can't see it for looking !!
                      cheers
