2 Replies Latest reply on Jun 5, 2009 6:09 AM by AdamofKCD
    Loader Component Sequence Question
    AdamofKCD
      Hello!
      I have multiple "Loader Components" placed in a grid that are working great for loading external JPEG's.
      However, when I publish my file the "Loader Components" load each image randomly (I assume because they load the smallest file in size first then next largest and so on).
      How do I load the content of multiple "Loader Components" in a specific sequence?
      Here is the script I have so far:
      ////"Thumb1" is the instance name of the first "Loader Component" in the grid. Next is "Thumb2", then "Thumb3" and so on
      Thumb1.load()
      if (Thumb1.percentLoaded >= 1 ) {
      Thumb2.load();}
      if (Thumb2.percentLoaded >= 1) {
      Thumb3.load();}
      if (Thumb3.percentLoaded >= 1) {
      Thumb4.load();}
      if (Thumb4.percentLoaded >= 1) {
      Thumb5.load();}
      I would LOVE to figure out how to accomplish this in AS 2.0
      Cheers!
      Adam
        • 1. Re: Loader Component Sequence Question
          clbeech Level 3
          hmmm... it's hard to say without seeing the rest of your code structure, that is how you are loading the contents and monitoring the progress events.  I would say that what you may want to do here is load each instance in sequence by using a 'complete' handler for each instance, increment an index and load the next instance.  something like this:
          var loaderArray:Array = [Thumb1, Thumb2, Thumb3, Thumb4, Thumb5];
          var loaderIndex:Number = 0;
          var loadListener:Object = new Object();
          loadListener.complete = function(e:Object) {
              if(loaderIndex < loaderArray.length-1) {
                  loaderIndex++;
                  loaderArray[loaderIndex].load();
              }else{
                  trace('loading complete');
          for(var instance in loaderArray) {
              loaderArray[instance].addEventListener('complete', loadListener);
          • 2. Re: Loader Component Sequence Question
            AdamofKCD Level 1
            This is brilliant, thank you very much!
            Cheers,
            Adam
