5 Replies Latest reply on Jun 1, 2009 1:36 PM by KNamuduri
    Problem Binding data to ComboBox
    KNamuduri Level 1
      Hi All,
      I am have been trying to do simple data to Combox using remote object.
      When I bind the data to DataGrid, I can see the data coming through. But when trying to assign it to Combobox by converting the result of remote object to Arraycollection. I have also provided the labelfield of the combobox but still no luck.
      I am providing the code below. Please help I need to finish a presentation.
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" applicationComplete="LoadDomains()" xmlns:ns1="Components.*">
                  <mx:Script>
                  <![CDATA[
                  import mx.controls.Alert;
                  import mx.utils.ArrayUtil;
                  import mx.events.DropdownEvent;
                  import mx.collections.ArrayCollection;
                  import mx.rpc.events.ResultEvent;
                  import mx.rpc.events.FaultEvent;
                  [Bindable] public var dpItemType:ArrayCollection;
                  private function LoadDomains():void
                  rptRoDomains.getDomains.send();
                  //    dpItemType = new ArrayCollection(ArrayUtil.toArray(rptRoDomains.getDomains.lastResult));
                      //    this.ItemTypeRO.getItemTypeByDom.send();
                  </mx:Script>
      //Remote Objec call
      <mx:RemoteObject id="rptRoDomains"  destination="domains" showBusyCursor="true"  fault="Alert.show(event.fault.faultString, 'Error');"/>
      <mx:HDividedBox>
      // Assiging it to Data grid which works
              <mx:DataGrid id="dgDomList"   dataProvider="{rptRoDomains.getDomains.lastResult}" width="30%" height="100%"   >
               <mx:columns>
              <mx:DataGridColumn dataField="dom" headerText="Domain" />
              </mx:columns>
              </mx:DataGrid>
              <mx:HBox>
      // Problem Area
      <mx:ComboBox id="cbItemType" width="150" prompt ="Select the ItemType " labelField="dom" dataProvider="{ArrayUtil.toArray(rptRoDomains.getDomains.lastResult)}"  >
      </mx:ComboBox>
      </mx:HBox>
      </mx:HDividedBox>
      </mx:Application>
        • 1. Re: Problem Binding data to ComboBox
          Flex harUI Adobe Employee
          Did you try:
          <mx:ComboBox id="cbItemType" width="150" prompt ="Select the ItemType " labelField="dom" dataProvider="{rptRoDomains.getDomains.lastResult}"  >
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: Problem Binding data to ComboBox
            *Prashant Shelke* Level 4
            Ensure that Objects present in your arrayCollection must contains properties data & label then only data will get render & also check that what length your getting for arrayCollection it should > 0
            Thanks.
            • 3. Re: Problem Binding data to ComboBox
              KNamuduri Level 1
              Hi Alex,
              I did try this option, but no luck.
              Karunya
              • 4. Re: Problem Binding data to ComboBox
                What did you get?  Can you show a complete example in 20 lines or so?
                Alex Harui
                Flex SDK Developer
                Adobe Systems Inc.
                • 5. Re: Problem Binding data to ComboBox
                  KNamuduri Level 1
                  Hi Alan,
                  I have written couple of JAVA classes to query the database which returns the List Object which is being called by Remote Object.
                  In the Flex I am callling the Remote object and binding the data to DataGrid and ComboBox. Data comes out fine in Datagrid not the ComboBox, I Get Object ,Object in the drop even after I have specified the labelField attribute in the ComboBox.
                  Here is the Flex Code :
                  <?xml version="1.0"?>
                              <mx:Script>
                              <![CDATA[
                          [Bindable] public var acLength:int;
                          private function getLisOfDomainsResultHandler(evt:ResultEvent):void
                              var domainList:Array = rptRoDomains.getDomains.lastResult as Array;
                              // fill the dataProvider with the data send back from the database
                              this.dpItemType = new ArrayCollection(domainList);
                              Alert.show( dpItemType.length.toString(),"Length of ArrayCollection");
                              </mx:Script>
                  <mx:RemoteObject id="rptRoDomains"  destination="domains" showBusyCursor="true"  fault="Alert.show(event.fault.faultString, 'Error');">
                          <mx:method name="getDomains" result="this.getLisOfDomainsResultHandler(event)" />
                  </mx:RemoteObject>
                  <mx:HDividedBox>
                           <mx:columns>
                          </mx:columns>
                          </mx:DataGrid>
                          <mx:HBox>
                  <mx:ComboBox id="cbItemType" width="150" prompt ="Select the Domain "
                      labelField="dom" dataProvider="{dpItemType}"  >
                  </mx:ComboBox>
                  </mx:HBox>
                  </mx:HDividedBox>
                  </mx:Application>
                  Thanks for the help.
                  Karunya
