• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Is paragraph alignment possible in RH 6 HTML?
New Here ,
May 28, 2009 May 28, 2009
Hi all,
Most of the topics I've created include text boxes, tables, and screen shots - all of which I can set the size for best viewing. But so far I haven't been able to find a way to control the paragraph text so that it doesn't stretch beyond the boxes, tables, and images when accessing the help pages without the content pane (TOC) open or having to minimize the page size. I've tried using the margin ruler, the paragraph alignment, and the page setup function, but nothing seems to do the trick. What I'm aiming for is nicely alignment topic when opened as a single help page or as part of a manual w/TOC.
I'd appreciate your input. Thanks!
Views
654
Translate
Translate
Report
Report
Community guidelines
community guidelines
Valorous Hero ,
Hi there
You are probably looking for something RoboHelp doesn't help you with easily.
If you hand edit the HTML code, you can insert a DIV on the page to make it adhere to a specific width.
Basically the HTML *MAY* look something like this:
This may make the editor look a bit odd as things are now inside a dotted rectangle frame. But it should work.
Cheers... Rick
Votes
Translate
Translate
Report
Report
New Here ,
May 29, 2009 May 29, 2009
Thanks, Rick! I tried what you suggested and I got the rectangle frame, but not the specified width. Then I tried just adding the "<div id=body>", saved it, clicked on the dotted frame, resized it, and the code came back with the body width which I could then edit. This was SO helpful!!
<div id=body
style=
"width: 708px; height: 124px;"
Votes
Translate
Translate
Report
Report
Guest
Note that you can set a width directly on paragraph styles.  For example:
p.Normal {
width: 90%;
or:
p.Normal {
width: 708px;
I may not understand the problem or solution exactly, but I think this would allow you to set a width without adding an extra div to control width.
Votes
Translate
Translate
Report
Report
Valorous Hero ,
LATEST
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
