2 Replies Latest reply on Jun 1, 2009 1:10 PM by zombee
    Web Service Problem!
      I'm creating a product selector, I've got a combo box filled with manufactorer names filled via a web service call.  Which works fine.
      Once the user selects the manufacturer, it then calls the next web service function to get a list of product to fill a data grid.  However, I get an error saying "Error opening URL", however, this is apart of the same web service as the last call.
      The code on combo box is:
      on (change)
      this._parent.getPhones_wsc.params = [this.selectedItem.MAKE];
      The trace statement supplies the correct item that was selected from the combo control, and when I trace the getPhones_wsc.params it returns the same as the selectedItem trace.
      I'm running coldfusion 8.1 developer version on a seperate server, which is running the flash too.
      As you may have noticed I am using AS2.0.  I know it's probably something stupid that I have forgot but I just can't see it, any help will be greatly appreciated.
      Many thanks in advance
        • 1. Re: Web Service Problem!
          MaxManNH Level 2
          Are you sure your scope is correct?
          "this" would refer to the combobox
          but does "_parent" refer to the webservice object? It seems like it might not.
          • 2. Re: Web Service Problem!
            zombee Level 1
            You are quiet correct the "this" refers to the combo box, and I double checked that the "this._parent.getPhones_wsc" does indeed point to the web service connector!
            This same code works in other examples I have seen dottered around the net, however, I've never been able to get web services to work!
            I am about to give up, and scrap both Flash and web services altogether!  See if Silverlight will do any better!
