9 Replies Latest reply on May 29, 2009 1:43 PM by kentgbaker
    Odd or Even Page selection
    kentgbaker Level 1
      Is there a typical way to define all odd pages in a document, as well as all even.
      I have scripts (with help from these forums) that do page rotations on the current page
      example:
      var crtpage = this.pageNum
      var crtpagerotate = this.getPageRotation({nPage:crtpage});
      try {
      this.setPageRotations({nStart:crtpage, nEnd:crtpage, nRotate:(90+crtpagerotate)%360});
      catch(e)
      app.alert("Processing error: "+e)
      But I would like to be able to rotate all odd pages 90, and all even pages 270
      Any help is appreciated
        • 1. Re: Odd or Even Page selection
          MarkWalsh Level 4
          Here's one way you can determine if the page number is odd or even:
          ((myPageNumber/2) == parseInt(myPageNumber/2))
          This will return true for even pages and false for odd pages. Rotate 270 if true, or 90 if false.
          • 2. Re: Odd or Even Page selection
            You could also use the "%" modulos operator to obtain the remainder of the division by 2  (modulos) of 1 (odd page) or zero (even page).
            if(this.pageNum % 2) {
            // result true  not 1 so even page
            app.alert("even - this.pageNum % 2: " + (this.pageNum % 2) );
            } else {
            // result false  1 so odd page
            app.alert("odd - this.pageNum % 2: " + (this.pageNum % 2) );
            So one could even use this result to either add 180 or 0 degree rotation adjusment.
            } else {
            var pRotate = 90;
            pRotate += ((this.pageNum % 2) % 2) * 180;
            app.alert("rotation: " + pRotate);
            • 3. Re: Odd or Even Page selection
              kentgbaker Level 1
              great,
              but I need to have the rotations happen on all pages of the document. I can use setPageRotations and define only the nEnd to get to all pages.......but how to get one rotation if odd, and a different rotation if even.
              Is there someway to loop through pages? then do the check for odd or even, then move on to the next page
              • 4. Re: Odd or Even Page selection
                Yes, you can use the JavaScript "for() {" loop control and use the "numPages" of the doucment object for the control value for the number of pages in the PDF.
                var pRotate; // degrees for page rotation
                for(i = 0; i < this.numPages, i++) {
                // compute rotation for this page
                pRotate =  90 + ((this.pageNum % 2) * 180);
                // rotate this page
                this.setPageRotations({nStart: i, nEnd: i, nRotate: pRotate });
                } // end page loop
                • 5. Re: Odd or Even Page selection
                  kentgbaker Level 1
                  Sorry,
                  console reports missing ; after for-loop condition, and I can't figure out what it needs.
                  • 6. Re: Odd or Even Page selection
                    kentgbaker Level 1
                    sorry, it was only the this.numPages;
                    • 7. Re: Odd or Even Page selection
                      kentgbaker Level 1
                      Thanks in advance,
                      here is where I am, stop me if this is the long way:
                      for(i = 0; i < this.numPages; i++)
                      var crtpagerotate = this.getPageRotation({nPage:?});
                      this.setPageRotations({nStart: ?, nEnd: ?, nRotate:(270+crtpagerotate)%360});
                      else {
                      this.setPageRotations({nStart: ?, nEnd: ?, nRotate:(90+crtpagerotate)%360});
                      notice the nStart: ?, nEnd: ?,  nPage:? this needs to be the page the loop is currently executing. Is this possible?
                      • 8. Re: Odd or Even Page selection
                        MarkWalsh Level 4
                        the variable 'i' will be your page number, so this should be what you want (untested)
                        if(i % 2) {
                        var crtpagerotate = this.getPageRotation({nPage:i});
                        this.setPageRotations({nStart: i, nEnd: i, nRotate:(270+crtpagerotate)%360});
                        else {
                        this.setPageRotations({nStart: i, nEnd: i, nRotate:(90+crtpagerotate)%360});
                        • 9. Re: Odd or Even Page selection
                          kentgbaker Level 1
                          Thanks everybody. I had used i as the variable at one point and could not get it to work. I will blame it on Friday. Thanks very much Mark.
