0 Replies Latest reply on May 28, 2009 9:43 PM by sathiyabala
    How to add string in editable datagrid
    sathiyabala Level 1
      Hai
             I have attached the mxml below.
         I need to add ' ' before and after the value.
         1. here i have the mxml, run the mxml , enter some vlaue in textbox and click add button, now the values will be added
         2. u can see the value in single quotes ie. ' '
         3. now u click the Value column  u can edit the value, after editing the value will not be in ' '
         4. here i have a problem, if the value is not in ' ' , i cant submit that query.
         5. how can i add ' ' after editing .
      can any one help me
      Thanks in Advance : )
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"
      <mx:Script>
      <![CDATA[
      // ActionScript file
      import
      mx.rpc.events.FaultEvent;
      import
      mx.controls.Alert;
      import
      mx.managers.CursorManager;
      import
      mx.collections.ArrayCollection;
      Bindable
      public var adhoc:ArrayCollection = new
      ArrayCollection();
      Bindable
      public var serverString = ""
      private function initImage(event:MouseEvent):void
      if
      (adhoc.length > 0){
      private function onChange():void
      if
      (comboBox.selectedIndex == 0){
      else
      private function onChange1():void
      if(combo2.selectedItem == "DATEDEPLOYED" || combo2.selectedItem == "DATEUPLOADED"
      datepick.visible =
      true
      txt.visible =
      false
      else
      txt.visible =
      true
      datepick.visible =
      false
      private function add():void
      var
      str:String = txt.text;
      if(str.length == 0 && txt.visible == true
      Alert.show(
      "Value Can Not Be Empty"
      return
      if(combo2.selectedItem != "DATEDEPLOYED" || combo2.selectedItem != "DATEUPLOADED"
      if(txt.visible == true
      var temp:Object = new
      Object();
      "'"+txt.text+"'"
      var
      str1:String = datepick.text;
      if
      (comboBox.selectedIndex == 1){
      if(str1.length == 0 && datepick.visible == true
      Alert.show(
      "Date Cannot Be Empty"
      else
      Object();
      false
      addopenbracket.enabled =
      false
      combo2.enabled =
      false
      combo1.enabled =
      false
      private function querydelete():void
      if
      (AdHoc.selectedIndex > 0) {
      if
      (AdHoc.selectedIndex == (adhoc.length-1)){
      adhoc[AdHoc.selectedIndex-1].cond =
      false
      addclosebracket.enabled =
      false
      addbutton.enabled =
      false
      combo2.enabled =
      false
      combo1.enabled =
      false
      // adhocdetailgridcompilance.dataProvider = null ;
      // adhocdetailgrid.dataProvider = null ;
      else if
      (adhoc.length == 1) {
      true
      true
      addbutton.enabled =
      true
      combo2.enabled =
      true
      combo1.enabled =
      true
      else
      Alert.show(
      "Select The Rows To Delete"
      private function andSubmit():void
      for each(var obj:Object in
      adhoc){
      if
      (obj.fname == combo2.selectedItem && obj.opera == combo1.selectedItem){
      trace("2 equals"
      Object();
      else
      trace(obj.fname + ":"
      + combo2.selectedItem);
      trace(obj.opera + ":"
      + combo1.selectedItem);
      trace(obj.val + ":" + "'"+txt.text+"'"
      else if
      (obj.fname == addclosebracket.label){
      trace("2 equals"
      Object();
      else
      if
      if(datepick.visible == true
      trace("2 equals"
      Object();
      else
      trace(obj.val + ":"
      + datepick.text);
      else if
      trace("2 equals"
      Object();
      else
      trace(obj.val + ":"
      + datepick.text);
      true
      true
      combo2.enabled =
      true
      combo1.enabled =
      true
      private function orSubmit():void
      adhoc){
      if
      trace("2 equals"
      Object();
      else
      else if
      trace("2 equals"
      Object();
      else
      if
      trace("2 equals"
      Object();
      else
      trace(obj.val + ":"
      + datepick.text);
      else if
      trace("2 equals"
      Object();
      else
      trace(obj.val + ":"
      + datepick.text);
      true
      true
      combo2.enabled =
      true
      combo1.enabled =
      true
      public function addOpenBracket():void
      Object();
      false
      true
      if(adhoc.length > 1 && addopenbracket.enabled == false
      addbutton.enabled =
      true
      public function addCloseBracket():void
      Object();
      if
      (adhoc.length > 1){
      true
      false
      if(adhoc.length > 1 && addclosebracket.enabled == false
      addbutton.enabled =
      true
      private function dateChange(date:Date):void
      if (date == null
      else
      txt.text = date.getDate() +
      '/' + (date.getMonth()+1).toString() + '/'
      public function saveadhoc(event:Event):void
      var AdhocRows:String = ""
      var
      i:int ;
      var
      selectedType = comboBox.selectedItem;
      /* if(editVal.substring(0,1) != "'"){
      if
      (adhoc.length == 0){
      Alert.show(
      "Enter The Query"
      else
      for
      (i = 0; i < adhoc.length;i++) {
      if(adhoc[i].fname != null
      AdhocRows = AdhocRows +adhoc[i].fname+
      if(adhoc[i].opera != null
      AdhocRows = AdhocRows + adhoc[i].opera+
      if(adhoc[i].val != null
      AdhocRows = AdhocRows + adhoc[i].val+
      if(adhoc[i].cond != null
      AdhocRows = AdhocRows + adhoc[i].cond+
      var parameters:Object = {adhocquery:AdhocRows,FlexActionType:"ADHOCQUERYSUBMIT"
      ,adhocType:selectedType};
      // adhocClick.send(parameters);
      private function retrieve():void
      false
      txt.visible =
      true
      </mx:Script>
      <mx:Array id="comp"
      <mx:String>TYPE</mx:String>
      <mx:String>AUDITRESULT
      </mx:String>
      <mx:String>CATEGORY
      </mx:String>
      <mx:String>CHILDRULE</mx:String>
      <mx:String>PARENTRULE
      </mx:String>
      <mx:String>AUDITGROUP
      </mx:String>
      <mx:String>LOCATION
      </mx:String>
      <mx:String>VENDOR
      </mx:String>
      <mx:String>DEVICECATEGORY
      </mx:String>
      </mx:Array>
      <mx:Array id="inven"
      <mx:String>VENDOR
      </mx:String>
      <mx:String>DEVICETYPE
      </mx:String>
      <mx:String>SERIES
      </mx:String>
      <mx:String>MODEL
      </mx:String>
      <mx:String>SUP/CPU
      </mx:String>
      <mx:String>CODEVERSION
      </mx:String>
      <mx:String>IMAGENAME
      </mx:String>
      <mx:String>DATEDEPLOYED
      </mx:String>
      <mx:String>LOCATIONNAME
      </mx:String>
      <mx:String>ADDRESS1
      </mx:String>
      <mx:String>ADDRESS2
      </mx:String>
      <mx:String>CITY
      </mx:String>
      <mx:String>STATE
      </mx:String>
      <mx:String>COUNTRY
      </mx:String>
      <mx:String>FLOOR</mx:String>
      <mx:String>CABINET
      </mx:String>
      <mx:String>CATEGORYNAME
      </mx:String>
      <mx:String>DEPARTMENT
      </mx:String>
      <mx:String>CONTACTNAME
      </mx:String>
      <mx:String>CONTACTNUMBER
      </mx:String>
      <mx:String>VERSION
      </mx:String>
      <mx:String>FILENAME
      </mx:String>
      <mx:String>DATEUPLOADED
      </mx:String>
      </mx:Array>
      <mx:Accordion x="13" y="55" width="230" height="492"
      <mx:Form
      label="AdHoc Query Analyzer" width="100%" creationComplete="retrieve()" height="100%" color="#F2F8F9" backgroundColor="#020202"
      <mx:Canvas label="Query" width="204" height="440" backgroundColor="#020202"
      <mx:ComboBox x="66" y="287" width="134" id="comboBox" dataProvider="[COMPLIANCE , INVENTORY]" change="onChange()" color="#050505">
      </mx:ComboBox>
      <mx:ComboBox x="5" y="344" width="109.25" id="combo1" dataProvider="[=,!=,>,>=,&lt;,&lt;=,LIKE]" color="#010101"
      ></mx:ComboBox>
      <mx:TextInput x="119.25" y="344" width="77.75" id="txt" color="#050505"
      <mx:Button x="3" y="401" label="Add" width="59" click="add()" id="addbutton" color="#FFFEFE" fillAlphas="[0.6, 0.4, 0.75, 0.65]" fillColors="[#FFFFFF, #CCCCCC, #EEEEEE, #EEEEEE]" borderColor="#B7BABC" themeColor="#009DFF"
      <mx:Button x="66" y="401" label="Delete" width="63.25" click="querydelete()" color="#FFFEFE" fillAlphas="[0.6, 0.4, 0.75, 0.65]" fillColors="[#FFFFFF, #CCCCCC, #EEEEEE, #EEEEEE]" borderColor="#B7BABC" themeColor="#009DFF"
      <mx:Button x="2" y="373" label="(" id="addopenbracket" click="addOpenBracket()" width="45" color="#FFFEFE" fillAlphas="[0.6, 0.4, 0.75, 0.65]" fillColors="[#FFFFFF, #CCCCCC, #EEEEEE, #EEEEEE]" borderColor="#B7BABC" themeColor="#009DFF"
      <mx:Button x="51" y="373" label=")" id="addclosebracket" click="addCloseBracket()" width="45" color="#FFFEFE" fillAlphas="[0.6, 0.4, 0.75, 0.65]" fillColors="[#FFFFFF, #CCCCCC, #EEEEEE, #EEEEEE]" borderColor="#B7BABC" themeColor="#009DFF"
      <mx:Button x="134.25" y="401" label="Submit" click="saveadhoc(event);initImage(event)" color="#FFFEFE" fillAlphas="[1.0, 0.69, 0.75, 0.65]" fillColors="[#77B97A, #77B97A, #EEEEEE, #EEEEEE]" borderColor="#77B97A" themeColor="#009DFF"
      <mx:ComboBox x="66" y="317" width="134" id="combo2" change="onChange1()" dataProvider="{comp}" color="#010101"
      </mx:ComboBox>
      <mx:DateField x="122.25" y="344" width="74.75" initialize="dateChange((event.target).selectedDate)" id="datepick" color="#050505"
      <mx:DataGrid x="1" y="1" width="203" height="282" id="AdHoc" dataProvider="{adhoc}" allowMultipleSelection="true" color="#020202"
      <mx:columns>
      <mx:DataGridColumn headerText="Name" dataField="fname" id="fnam"
      <mx:DataGridColumn headerText="Operator" dataField="opera" id="ope"
      <mx:DataGridColumn headerText="Value" dataField="val" id="valu"
      <mx:DataGridColumn headerText="Condition" dataField="cond" id="condt"
      </mx:columns>
      </mx:DataGrid>
      <mx:Button x="99" y="373" label="AND" width="52" click="andSubmit()" id="and" color="#FFFEFE" fillAlphas="[0.6, 0.4, 0.75, 0.65]" fillColors="[#FFFFFF, #CCCCCC, #EEEEEE, #EEEEEE]" borderColor="#B7BABC" themeColor="#009DFF"
      <mx:Button x="154" y="373" label="OR" width="49" click="orSubmit()" id="or" color="#FFFEFE" fillAlphas="[0.6, 0.4, 0.75, 0.65]" fillColors="[#FFFFFF, #CCCCCC, #EEEEEE, #EEEEEE]" borderColor="#B7BABC" themeColor="#009DFF"
      <mx:Label x="7" y="291" text="TYPE" width="59" fontWeight="bold"
      <mx:Label x="5" y="319" text="DISPLAY" width="59" fontWeight="bold"
      </mx:Canvas>
      </mx:Form>
      </mx:Accordion>
      </mx:Application>
      datepick.visible =
      Alert.show("Inside IF111::::;"+AdhocRows);
      AdhocRows = "'"+adhoc[i].val+"'";
      //AdhocRows = AdhocRows + adhoc[i].val+" ";
      if(editVal.substring(editVal.length-1,editVal.length) != "'"){
      Alert.show("Inside IF 222::::;"+AdhocRows);
      AdhocRows = adhoc[i].val+"'";
      date.getFullYear().toString() ;
      temp.fname = addclosebracket.label
      adhoc.addItem(temp);
      temp.fname = addopenbracket.label
      addbutton.enabled =
      obj.cond = or.label
      adhoc.setItemAt(obj,adhoc.getItemIndex(obj));
      obj.cond = or.label
      obj.cond = or.label
      obj.cond = or.label
      addbutton.enabled =
      obj.cond = and.label
      adhoc.removeItemAt(AdHoc.selectedIndex);
      combo2.selectedItem = adhoc[adhoc.length-2].fname
      combo1.selectedItem = adhoc[adhoc.length-2].opera
      addbutton.enabled =
      temp.fname = combo2.selectedItem;
      temp.opera = combo1.selectedItem;
      temp.val = datepick.text;
      datepick.text =
      txt.text =
      temp.val =
      CursorManager.setBusyCursor();
