Premiere Pro CS4 4.1.0 is live
Sheri Codiana May 28, 2009 11:05 PMThe update is now available via AUM, and will be available soon on the Adobe.com updates page. The readme will also be posted at http://www.adobe.com/go/pr_readme_en, but until then, here's the info on the release (multi-lingual readme is also attached):
New in this release
- Additional support for REDCODE (please visit RED support for additional details).
- Performance improvements to project load time.
- Improvements to AVCHD support.
- Performance enhancements for DV/HDV playback.
- Support for Avid captured DV or IMX footage. (Please see www.adobe.com/go/kb409079 for additional information).
- Export media to a still format now bypasses the AME render queue.
- Enabled .VOB extension support.
- Third-party support
Notable fixes
- All clips in last active sequence are no longer redbar when reopening project (#2278647)
- Boris FX can get the clip dimensions for their filter setup dialog (#2274629)
- CTRL+M is now the default shortcut for File‐>Export‐>Media (#2277908)
- A bug that caused green frames in clips with 100% reverse speed applied has been fixed. (#2263918)
- The last few frames of a time remapped clip are no longer rendered green (#2278907)
- Adobe Premiere Pro can now open projects created in Adobe Premiere Elements 7. (#2267281)
- ’Scale to Framesize’ on a clip in a sequence of matching frame size and PAR no longer causes the timeline to require rendering. (#2278908)
- A bug that caused corruption in exported TIFF files has been fixed. (#252497)
- Several issues with Adobe After Effects Filters and Track Mattes have been fixed. (#1882807,
- #1876369)
- Performance improvements have been made to Direct Manipulation (#2260316)
- AVCHD 720p 30p are now imported correctly. (#2269541)
- Relinking XDCAM EX clips that have been moved to a new directory is now more intuitive.
- (#2272122)
- A bug that caused fields to be reversed when rendering speed change on upper field first footage has been fixed. (#2260314)
- A user can now copy and paste R3D footage from Adobe After Effects to Adobe Premiere Pro. (#1931580)
- Several issues with effects that use track inputs, when the input track is a still have been fixed. (#2263816)
- Playback performance of ProRes clips has been improved. (#2261047)
- Playback performance of h.264 clips has been improved. (#1824690)
- XDCAM EX clips no longer play one only audio track in the Source panel (#1929452)
- A playback issue with Panasonic AG‐HMC150 recorded progressive AVCHD clips no longer causes application freeze (#2268148)
- Blackmagic can now display titler output on external monitor (#2286733)
- If a mapped drive is defined as the user folder for a roaming profile, Adobe Premiere Pro no longer crashes when attempting to write to the drive (#2291950)
Known issues
- Progressive 720 Sony AVCHD media files show an interlaced frame rate in Media Browser and Metadata panel.
- AVCHD 1080p 30 and 25 progressive clips are interpreted as interlaced files in Adobe Premiere Pro CS4 projects.
- If the work area end position is greater than the last frame of the last clip in sequence, then entire sequence is exported instead of work area.
- Setting sequence-marks stops playback if the multi-camera monitor is open.
- When importing QuickTime clips in AME’s batch queue for export, certain types of metadata (such as timecode) will not be propagated to newly generated clips.
