2 Replies Latest reply on May 29, 2009 5:00 PM by Michael Borbor
    Processing RemoteObject data Step by Step
    ProjectedSurplus Level 1
      My <mx:RemoteObject> hits a CF8 cfc and I can bind to the results using    text="{svcColdFusion.GetHello.lastResult}"
      I thought I read in liveDocs that RO's return ArrayCollections by default -- is this correct and/or does the cfc's     returntype="   " affect this?
      Or if this is incorrect, then I assume I must cast the RO resultEvent to an array collection?
        • 1. Re: Processing RemoteObject data Step by Step
          From all examples thus far it seems as though the RemoteObject resultEvent must be cast to an ArrayCollection.  Not sure if this can be done in an <mx:ArrayCollection> (comments welcome) rather than in a script block but this works: (for anyone following along my learning path)
          <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml" initialize="svcColdFusion.NewVisitor()">
              <mx:Script>
                  <![CDATA[
                      import mx.collections.ArrayCollection;
                      import mx.rpc.events.ResultEvent;
                      import mx.controls.Alert;
                      import mx.rpc.events.FaultEvent;
                      [Bindable]
                      private var myArray:ArrayCollection
                      private function if_RO_Fault(event:FaultEvent):void {
                          mx.controls.Alert.show(event.message as String, "Service Error");
                      private function if_RO_Result(event:ResultEvent):void {
                          myArray = event.result as ArrayCollection;
              </mx:Script>
              <mx:RemoteObject id="svcColdFusion"
                  destination="ColdFusion"
                  endpoint="http://___your IP num____::8500/flex2gateway/"
                  source="test.cfcs.helloworld" >
                      <mx:method name="SingleRow" fault="if_RO_Fault(event)"
          result="if_RO_Result(event)"/>
              </mx:RemoteObject>
          <mx:VBox>
              <mx:DataGrid id="DG1" dataProvider="{myArray}" />
                <mx:Label id="Lbl1" text="{myArray.getItemAt(0).familyName}" />
          </mx:VBox>
          </mx:Canvas>
          Now for the tricky part (IMHO). Correct me if I am wrong, but to separate View from Model, best practice is to NOT directly use the specific elements {myArray.getItemAt(0).familyName} as above but rather to convert them to a Value Object then use that VO to populate attributes.?????
          • 2. Re: Processing RemoteObject data Step by Step
            Michael Borbor Level 4
            Well in that case what you could do is myVOEntity=myVOEntity(myArrayCollection.getItemAt(0))
