Does Connect track results from Captivate's assessment simulation?
Also, If you import a Captivate assessment simulation into a Presenter presentation, are the assessment simulation results still tracked when the Presenter file is published to Connect?
Thank you!!!
Connect will track the simulation interactions in Captivate (assuming you have told them to report as part of the quiz).
However, if you embed it into a Presenter Presentation, you will not have the ability to track the interactions. The better workflow there is to have the Captivate project external to the Presenter project and give access to it via hyperlink.
