3 Replies Latest reply on May 31, 2009 12:38 AM by New_With_Flex
    addEventListener() is not working !!
    New_With_Flex
      Hello Everybody,
      I am new in Flex. Trying to add event listener to a custom shape. I was not able to make it working.  Could anybody help me out ? The code is given below.
      <mx:Application
      xmlns:mx=http://www.adobe.com/2006/mxml layout="absolute" creationComplete="init();">
      <mx:Script>
      <![CDATA[
      import mx.controls.Alert;
      public function handler():void
      Alert.show(
      "hello..");
      public function init():void
      canvas1.addEventListener(MouseEvent.CLICK,handler);
      Alert.show(
      "Creation complete");
      </mx:Script>
      <mx:Canvas
      id="canvas1" width="686" height="204" borderColor="#270D14" backgroundColor="#710404"/>
      </mx:Application>
      If I add the property to the canvas click="handler();" , then it works. But, it does not work, if added inside the script. Any idea, where I am missing the point.
      Thank you in advance.
        • 1. Re: addEventListener() is not working !!
          Michael Borbor Level 4
          Set your event handler function like this
          public function handler(e:Event):void
          Alert.show(
          "hello..");
          • 2. Re: addEventListener() is not working !!
            *Prashant Shelke* Level 4
            your parameter missing in the event listener function... This parameter is required to get information about object from which its generated.
            Thanks.
            • 3. Re: addEventListener() is not working !!
              New_With_Flex Level 1
              Thank you so much. This was really helpful.
              What I am trying to do is, I have created a canvas and the background of that canvas is an Image ( map ). On that map, I have drawn circles and middle of that circle I have added a label.
              Now, I can add the event listener to the canvas the way you showed, but can not add to individual circle. The circle is drawn in a seperate AS class. I am trying to click on the circle and the circle will do some effect (zoomin, zoomout etc..).
              Could you please help me out.
              Thank you so much again.
              Let me put the source code here.
              //Badge.as
              package
              asset
              import
              flash.display.Shape;
              import
              flash.events.MouseEvent;
              import
              mx.controls.Alert;
              public class Badge extends
              Shape
              public function
              Badge()
              super
              //drawBadge();
              //private function drawBadge():void
              public function drawBadge(x:int,y:int):
              void
              graphics.clear();
              graphics.lineStyle(1,0xFF0000);
              graphics.beginFill(0xFF0000,1);
              graphics.drawCircle(x,y,10);
              graphics.endFill();
              addEventListener(MouseEvent.MOUSE_OVER,handleEvents);
              private function handleEvents(event:MouseEvent):
              void
              Alert.show(
              "from the event handle"
              ////////test.mxml////////////////
              <mx:Application
              xmlns:mx="http://www.adobe.com/2006/mxml
              layout="
              vertical
              width="
              100%
              height="
              100%
              scroll="
              true
              creationComplete="drawMarkers()"
              <mx:Script>
              <![CDATA[
              import
              mx.events.EventListenerRequest;
              import
              mx.collections.ArrayCollection;
              import
              mx.controls.Text;
              import
              mx.controls.Label;
              import
              mx.controls.Alert;
              import
              mx.core.UIComponent;
              import
              import
              asset.Badge;
              Bindable
              private var uiComponent:UIComponent = new
              UIComponent();
              public function handleMouseEvent(event:MouseEvent):
              void
              Alert.show(
              "mouse event"
              private function drawMarkerAt(x:int,y:int,val:int):
              void
              x = x - 50;
              var bdg:Badge = new
              Badge();
              //bdg.drawBadge(x-drawingImage.x,y-drawingImage.y);
              bdg.drawBadge(x,y);
              uiComponent.addChild(bdg);
              var label1:TextField = new
              TextField();
              label1.text=val.toString();
              if
              ( val < 10)
              //label1.x = x-drawingImage.x-4;
              //label1.y = y-drawingImage.y-8;
              label1.x = x-4;
              label1.y = y-8;
              else
              //label1.x = x-drawingImage.x-7;
              label1.x = x-7;
              label1.y = y-8;
              var textformat:TextFormat = new TextFormat(null,10,0xFFFFFF,true
              label1.setTextFormat(textformat);
              uiComponent.addChild(label1);
              drawingImage.addChild(uiComponent);
              private function drawMarkers():
              void
              //drawingImage.addEventListener(MouseEvent.CLICK,handleMouseEvent);
              var labLocationsX:Array = new
              Array(183,250,310,327,363,394,461,430,286,332,416,247,268,312,315,362,384,429,237,307,247 ,304,301,360,398,428,457);
              var labLocationsY:Array = new
              Array(221,237,183,225,228,226,228,254,286,287,291,332,332,327,368,366,381,409,430,440,482 ,467,493,485,487,480,592);
              for(var
              i:int = 0;i<27;i++)
              drawMarkerAt(labLocationsX[i],labLocationsY[i],
              /*Math.random()*30*/
              i);
              </mx:Script>
              <mx:Zoom id="zoomIn" duration="1000
              zoomHeightTo="
              2" zoomWidthTo="2"
              <mx:Zoom id="zoomOut" duration="1000
              zoomHeightTo="
              1" zoomWidthTo="1"
              <mx:Canvas id="drawingImage
              backgroundImage="
              @Embed(source='map.png')
              width="
              592" height="718"
              <!--click="handleMouseEvent();"/>-->
              </mx:Application>
