1. Re: 4.1 error message!!
Harm Millaard May 30, 2009 9:06 AM (in response to harrismail)You have to wait till it gets out of the queue before anybody can make any sense of it. May be 24+ hours.
2. Re: 4.1 error message!!
Curt Wrigley May 30, 2009 9:11 AM (in response to harrismail)Use the camera icon to paste the image into the post . It gets posted immediately. Attachments have to be scanned and the porcess seems buggy.
4. Re: 4.1 error message!!
Harm Millaard May 30, 2009 9:30 AM (in response to harrismail)I haven't seen this one, but obviously it thinks it must access the A drive, I suggest you download again, either using AUM and automatically install, or download from the Adobe site and run the downloaded file.
5. Re: 4.1 error message!!
harrismail May 30, 2009 9:34 AM (in response to Harm Millaard)Reluctant to do that as everything seems to be just fine if I click "try again" !!!! It doesn't happen all the time too ?
Weird ?
Anyone out there seen this? or have any idea as to what might cause it?
Steve
6. Re: 4.1 error message!!
Eddie Lotter May 30, 2009 10:37 AM (in response to harrismail)Are any of your preference settings set to use the A: drive? Just a shot in the dark.
Cheers
Eddie -
7. Re: 4.1 error message!!
Harm Millaard May 30, 2009 10:54 AM (in response to harrismail)Reluctant to do that as everything seems to be just fine if I click "try again" !!!! It doesn't happen all the time too ?
Luckily you only need to download and install once. If it works after try again, there is no need to repeat it. For the rest, it is weird.
8. Re: 4.1 error message!!
don solomon May 30, 2009 11:05 AM (in response to harrismail)Hi,
Yes I have had that several times, but not just wih Pr 4.1. My machine has no A drive, but some software can't seem to figure that out. Actually, that message just started with my SP2 upgrade to 64 Ultimate. It is a click through fix and occurs infrequently, and with no apparent consequences, so not worth my time to troubleshot until there is some consequence to it.
9. Re: 4.1 error message!!
harrismail May 30, 2009 11:27 AM (in response to don solomon)Cheers Don,
I'll keep an eye on it ;-)
Steve
10. Re: 4.1 error message!!
Kostas Arvanitidis Jun 2, 2009 3:05 AM (in response to harrismail)Hey all,
I also got this message. Also without an A:/ Drive... what i did is disabled from bios the A:\ drive (even if it doesn't exist it is registered) and also disabled the Floppy ATA port (also from bios)... Message never re-appeared (so far)
