3 Replies Latest reply on Jun 1, 2009 3:46 PM by gkaiseril
    Printing one file to multiple printers
    EmperorsDryCleaner
      I think this is the right section.  If not, please forgive me.
      I'm trying to make, if possible a button on the toolbar that will print two copies to one printer, and one copy to another printer.
      Is that even possible?
      Thanks.
        • 1. Re: Printing one file to multiple printers
          Yes, you need to use the "PrintParams" object to identify the printer name and number of copies to print.
          • 2. Re: Printing one file to multiple printers
            EmperorsDryCleaner Level 1
            Thanks!
            I started reading about "PrintParams", and I quickly discovered that I am a bit lost as to exactly how to use it, and how to make a toolbar button to do it.
            Is there, anywhere, a graphical walk-through of how to make a toolbar button, and then attach some javascript to it?  Everything I have read so far seems to assume I already know quite a bit more about programming for Acrobat than I do.
            Cheers!
            • 3. Re: Printing one file to multiple printers
              First, I would work on creating a 'print' button.
              You need to know the printer names assigned on your system. The following code can be run in the JavaScirpt console and display a list of printer names:
              var l = app.printerNames.length
              for ( var i = 0; i < l; i++)
              console.println("(" + (i+1) + ") " + app.printerNames[i]);
              With that one can then set the printer parameters for the print command:
              var myParams = this.getPrintParams();
                myParams.NumCopies = 2;
                myParams.interactive = silent;
                myParams.printerName = "system printer name 1";
                this.print(myParams);
                myParams.NumCopies = 1;
                myParams.printerName = "system printer name 2";
              This will work from the console, but inorder to use the silent parameter, you will need to create a menu item to get around the priviledged and trusted funcitons.
