1 Reply Latest reply on Jun 1, 2009 1:23 PM by Gaurav J
    Q: Increase the heap space for ant...set ANT_OPTS..where??
    jbach2 Level 1
      In trying to resolve the out of memory error I get when running Ant on a large project of mine I cam across this post
      http://tech.groups.yahoo.com/group/flexcoders/message/102140
      set the following environment variable before the build depending on
      your platform.
      //CODE START
      set ANT_OPTS=-Xmx500M
      or
      set ANT_OPTS=-Xmx500M ; export ANT_OPTS
      //CODE STOP
      My question is, where does one make this change (set ANT_OPTS)??
        • 1. Re: Q: Increase the heap space for ant...set ANT_OPTS..where??
          Gaurav J Adobe Employee
          short answer:
          In command prompt or cygwin.
          long answer:
          if you are uisng comman prompt call
          before calling the ant command.
          if you using cygwin use
          export ANT_OPTS=-Xmx500M
          In case you are using unix based OS. use
          Also you can set ANT_OPTS as an enviornment variable.
          Gaurav Jain
          Flex SDK Team
