1 Reply Latest reply on Jun 1, 2009 1:20 PM by Gaurav J
    'two swf' It is urgent pls help me
    ritesh_gcet
      i have put two swf in one parent using <mx:SwfLoader>, both swf's having 'olapDataGrid' for diffrent-2 purpose. during the running of  the application the 'style manager' will give the error, when i have run those appliction under diffrent-2 parent applictions, both are running perfectully, without any 'style manager' problem. pls help me why those 'swf's' creating problem if i run within one parenty appliction????
        • 1. Re: 'two swf' It is urgent pls help me
          Gaurav J Adobe Employee
          whats the error that you get?
          If I have to guess then you might be running into class loading issues (which may be causing a conflict between the two definitions). Try defining (add an import and define a variable of type) the StyleManager (or the manager class which is giving you the error) in the main app.
          Gaurav Jain
          Flex SDK Team
